Master How-T o Sticky!!
As I now have the POWA to make such a thing, I have decided to compile all the how-to’s into one thread (with links anyways the OP’s will stay but this master list will reference each of those threads so they are really easy to find) This way people can check the sticky for the how-to’s in categories.
Post in this thread if a new how to is made that I have missed.
On to awesomeness.
Appearance How-To’s:
Spray tint tail lights A
Spray tint tail lights B (coupe)
Side Mirror Center Removal
Vanity Mirror Fix
Outside Mirror Take off with instructions
Painting Side Skirts
Front Bumper Removal
Removing and replacing door handles
Removing Chrome Window Trim
Splatter Paint
Removing Badges
Installing washer nozzles on wipers
Rebadging
Opening Headlights
Un-Tinting Tail lights
Removing lower grilles
Removing upper grilles
Painting GTP Rims
Front Dart Removal
Painting Headlight Bezels
Removing Front Plate
Trunk Cut Outs
Eyelids
Coupe Tail Light Removals
Removing Pin Stripe
Alienationz's Eyelids
Performance and Maintenance How-To’s:
How to change spark plugs and wires on LX9
Racingline Motormounts
Replacing Front Sway Bar Bushings
Installing Rotors and Brake Pads
Replacing Front Hub Bearing
Lube Intermediate Shaft
Oil Change 1
Oil Change 2 (W/DUI..Thanks Pooners!)
Fixing Sunroof Drain Tube (non-Pano)A
Fixing Sunroof Drain Tube (non-Pano)B
Installing a Spring/Lowering Kit
Ram Air Through Grille
Removing Air Bag Module
Replace Thermostat on a 3.9L
Removing Gas Door
Installing Coilovers
Removal of Seatbelts
Installing GT-R on a Convertible
Breaking in Rotors
Installing 3.6L Intake Manifold Insulators
Build your own CAI
Making a GXP Hood Functional
Installing Dr. Speed Stage 3 CAI (fenderwell)
Changing Outer Tie Rod
How to Make a Lid for your CAB
CRAB Install on 3.6
Properly Removing Wheels
Ebay Intake Install
Removing intake Resonator 1
Removing intake resonator 2
Short Belt on 3.6
Installing Vector HSRK
Anti-Theft Fuel Shut off
Removing TCM on 3.9
Removing ECU
How To Remove Throttle Body
Keeping your GT-R In Place
Resetting Indexing Windows on Coupe
Disabled 6 Spd Reverse Lockout
Changing F40 Fluid
Brake lights staying on? Here is a vid on the fix!
Interior Component How-To’s :
Folding down Backseats in a G6
Interior Door Trim - See post 2
Removing Door Panels (front)
Door Panels 2
Removing A-Pillar
Dome Light Rattle
Installing Cabin Air Filter
Dome Light Removal
Removing Bugs from Map Lights
Replacing Blower Motor
Removing door switches
Glove box fix
Installing White face Gauges
Remove Vents
Removing 6 Speed Shift Knob
Removing Auto Shift Knob
Removing Instrument Panel Bezel
On to awesomeness.
Vanity Mirror Fix
Splatter Paint
Removing Badges
Rebadging
Opening Headlights
Painting GTP Rims
Front Dart Removal
Trunk Cut Outs
Eyelids
Removing Pin Stripe
Oil Change 1
Removing Gas Door
Breaking in Rotors
Build your own CAI
CRAB Install on 3.6
Ebay Intake Install
Short Belt on 3.6
Removing TCM on 3.9
Removing ECU
Changing F40 Fluid
Door Panels 2
Removing A-Pillar
Dome Light Rattle
Dome Light Removal
Glove box fix
Remove Vents
