alright so i looked and didnt see one unless i just over looked it, so here is a how to on the install for fog lights and HID kits
1. Open hood
2. Take out Headlights - how to here is one = viewtopic.php?f=29&t=18195
3. Twist out old bulb
4. Mount ballast, i mounted the passenger side on on the metal framing below/beside the intake hole
You have to drill a hole to mount the ballast, i also recommend using double sided tape to help hold it too.
5. Install bulb and hook up wires for passenger side. This of course will vary with kit so you are on your own for that. I recommend test fitting the light before hooking wires up, i had to sand down some of the clips so it fit without breaking one off.
6. Mount driver side ballast. I actually couldnt find a good spot on the driver side, there was to many things in the way (horn/washer fluid/etc). However i did find this nice handy hole for it right behind the headlight.
i put the wires facing the front of car and it slide right in the hole. it would not go the other way but i guess you could try. it fits nice and snug and isnt going anywhere, so i didnt use a single thing to hold it in place, just let it sit in there.
7. repeat step 5 for driver side
8. TEST TO MAKE SURE BULBS ARE WORKING!!!!!
9. zip tie the wires up to the factory ones. this will keep them from laying where water might get to them and off the bottom plastic pieces.
10. Reinstall headights.
11. close hood
12. enjoy your new light output
ALSO:
for those that dont have the extra black box for relays, you could just mount your ballast in that spot. see first picture for what im talking about.
any questions just ask and hope this helps some people out in the future
1. Open hood
11. close hood
ALSO:
