I had pulled my battery one day and came back to a cd changer error...well after I got my new 08 with aux cd changer i decided to do some investigation work on the old 06 6 cd changer/radio
Remove the 4 screws on the faceplate
Remove faceplate by lifting tabs
Pop off the top by force
Now we are in!
Remove the tiny black screws
Now push the scissor area as shown back and lift up your cd's
You will find a few metal pieces that have come dislodged...this is the problem maker! Remove them and your cd's with some wiggling..by pushing up the scissor metal piece it can be done
I was unable to get the metal pieces to go back on...you will notice there are 6 of them...these are what move your cd's to and from the play area...I have two that are left in tact so now I have a 2 cd changer lol
(not pictured other two on the table)
Below is the spindle that holds the metal pieces, that hold your cd's
I HAVE NOT TRIED TO PLUG IN MY CD PLAYER SINCE I TOOK IT APART...I DID THIS MOSTLY TO GET MY CD'S OUT. I HAVE A GOOD FEELING THOUGH THAT THIS SHOULD FIX THE CD CHANGER. AS LONG AS YOU ONLY LOAD AS MANY CD'S AS THERE ARE CD CHANGER METAL SEPERATORS!
HOPEFULLY SOMEONE CAN ADD TO WHERE I LEFT OFF AT
oh yes...and DO NOT do this while there is power to the cd changer...this is a warning sticker that says "DANGER INVISIBLE LAZER RADIATION WHEN OPENED"
Now we are in!
