HOW TO lube Intermediate steering shaft
  • HOW TO lube Intermediate steering shaft
    as warrentys start to expire and steering shafts begin to clunk who wants to take it to a dealer to get it lubed when you can lube it yourself provided it is not a painted style i shaft. painted styles became standard on 2009 and up models but any 6 thats been to a dealer for the clunk noise and they replaced the shaft COULD have a painted i shaft. only way to tell is to visually inspect it to do that youll need to remove the close out panel on the drives side which is outlined in the first step
    #1 is a non painted i shaft that CAN be lubed
    #2 is a painted i shaft. If yours looks like that DO NOT LUBE!!!!!
    there are 2 ways to lube ill provide both
    both start the same way
    remove the plastic close out panel under the drivers side of the insterment panel. it is held on with 2 7mm bolts
    then there is a clip for the hood release cableon the panel. you just have to squeeze in the 2 tabs and it comes right out.
    from there you have access to the i shaft
    IMPORTANT: if after seeing the i shaft you notice that it has been painted DO NOT LUBRICATE. That "painted i shaft" does not tolerate lube and lubricating will only make the problem worse
    the first way to lube it it to remove the pinch both from the top of the shaft(11mm) then pull it off the steering column
    DO NOT TURN THE STEERING WHEEL WITH THE SHAFT DISCONECTED DAMAGE TO THE AIR BAG COIL COULD RESULT. slight movement is ok but do not spin the wheel
    with the shaft disconected fully extend it and place lube(GM part number 26098237) on the lowest part of the shaft where the 2 haves meet.
    after applying the lube you need to "exercise" the shaft in and out a few times. you can then reinstall the shaft to the column and reinstall the closeout panel.
    the second way does not require the shaft to be disconected from the column. all you have to do is after removing the closeout panel sparay lube inbetween the 2 shafts.after spraying turn the wheel 180 degrees and spray some more on the other side of the shaft as well. i use GM Superlube(p/n12346241) but i would imagine white lithium grease would have the same effect. this method is not as effective as the first method but it does work
    Re: HOW TO lube Intermediate steering shaft
    great how to andy.
    Show
    -20% tint
    -bohaman AUX-in radio mod
    -Professionally heated seats
      sweet thanks andy
      My progression thread
      Car: Black 2007 G6 V6 Sedan
      Done: Debadged, 20% tint, Stage 3/4 CRAB Intake, 08 radio w/aux, leather wheel and radio controls, DDM Tuning 6K HID's
      In Process (waiting on the install): Black Window Trim, GTP rims, Red painted Calipers
      Near Future: Red Angel Eyes, Cquence rotors, color matched headlights, LED tails+3rd brake light
      Down the Road: WAMS tune
        gooood. goooood. (family guy)
        thanks a bunch andy
        Mods: 30% tint front, 18% tint rear, custom eyelids, custom painted rocker panels, custom painted side/wing mirrors, GXP front bumper/fascia, eibach pro kit springs, 17" black/machined face liquid metal venoms, interior CF kit, K&N typhoon intake, Flashtech HID's 6000K lows, 10,000K fogs, Xenon 8500k highs.
        Other ride: 07 Q7 for now
        PSN: racin247
        Progression-search Silverg6er's FOTOZ
          thanks a bunch andy
          2009 PONTIAC G8
          MAGNETIC GRAY METALLIC
            thanks a bunch andy
            [youtube:2klrb1cn]http://www.youtube.com/watch?v=dex5BJAF73k[/youtube:2klrb1cn]
            no embedding for you.
            Show
            -20% tint
              General question for everyone ...
              can the lower (thicker) part of the shaft be drilled and tapped and then have a grease nipple screwed on so you can grease up the shaft without removing it ???
              Thoughts??
              2006 G6 GTP 6spd. Black on Black
                ive heard of it being done ive never seen it but i dont see y not
                  would it be worth doing it to lube it once possibly twice? IDK, maybe
                  '08 G8 GT... 1 7/8" Kooks Blue Ceramic Coated Long tube Headers... 3" Xpipe...Magnaflow axle backs...Rotofab CAI...Heater hose relocate. Ported throttle body, intake manifold, Custom grind cam 227/237 .620/.604 LSA 113 +3, Circle D 3200 stall, 3.45 rear gear,Tuned by Redline
                  Dyno 438 WHP 415 WTQ
                  '15 Chevy SS Some Like It Hot Red Holden Grill & trunk badge... Solo performance axle backs... Rotofab Intake, Mobile attractions front splitter
                    if it stops the knock /noise.... it is definately worth doing ... lol
                      by exercise you mean....
                      and if this eliminates my clunking i'm going to give you an e-high five
                      Fusion Orange Metallic Owner? Click!
                        I've never had the problem, So.........
                          BUMP
                          for picture of the 2 style ishafts
                            This why you get paid the big bucks
