I recently needed to look at the wiring inside the steering column and I needed to remove the front part of the steering wheel which is actually the Airbag module (The center of the steering wheel that has the Pontiac emblem and you push on to beep the horn).
Here's what I was told to do by the service department and it turned out to be quite easy. I'll have more photos of the actual module coming off whan I redo this next weekend.
Tools:
- 3 - 4" long thin nail with the end ground flat or some other such item. We'll call it a pin
- Small open end wrench (for the battery disconnect).
Time:
- 5 minutes
1) Disconect the negative of the battery for safety (Don't want to have the Airbag go off in your face as unlikely as that might be). You'll have to remove the battery cover to get at the battery.
2) Note: There is a small hole in the left and right side of the steering column that you will push the pin into releasing a spring that holds in that side of the airbag module. The tricky part is to exactly hit the pin head onto the spring. This is why you want to flatten the tip of the pin to make that easier to do.
So, starting with the right side, turn the steering wheel to the left to gain access to the small hole. Push the pin into the hole while pulling lightly on the right side of the airbag module. You should be able to feel the spring move back and forth as you push the pin in and out slightly. When you push the pin in enough the right side of the airbag module should pull out toward you as you pull on it. Pushing the pin into the hole and pushing back the spring will not automatically release the airbag module you must pull on the airbag module while the spring is depressed.
3) Repeat for the left side this time turning the steering wheel to the left to get a better look at the pin hole.
4) Once the Airbag module is free I just moved it out of the way and did not disconnect any wires as I didn't want to break anything.
5) Replacement is simply center the airbag module over the steering wheel and gently push it back into place.
Pictures:
The Airbag Module (Front of the Steering Column with Pontiac emblem)
Pin I used (Small nail that I would flatten the end more on)
Right Side Pin Usage
Another Right Side Image
Left Side
Tools:
Time:
- 5 minutes
Pictures:
Left Side
