the front pillars how do they come off? like the back ones just pull them off? or is there a speacial way on taking them off?
a-pillar
a-pillar
2006 Black GTP Coupe, One of the First Hammerhead Spoilers on here. Gm Strut Bar, Doctor Speed CAB and Stage 4 . Black out upper grille and black logos, Tinted Black Euro's, Painted black Headlights with blacked out corners and Led's,10,000 K HID Low-Beams, GT-R Cat-Back Exhaust System,Racingline performance moto mounts inserts, power slot rotors and hawks.Eclipse 4 channel amp powering Alpine Type-S speakers, 93 oct tune, GM HSRK, RaceineLinePerformance Ground Kit.Tags: None
Re: a-pillar
See the little cut out in the center toward the top?
Peel it back with a small flat head screwdriver. You will see a bolt behind it.
Remove that bolt and it will pull off.Please consider supporting G6P -Tap here
Re: a-pillar
thank you poon2006 Black GTP Coupe, One of the First Hammerhead Spoilers on here. Gm Strut Bar, Doctor Speed CAB and Stage 4 . Black out upper grille and black logos, Tinted Black Euro's, Painted black Headlights with blacked out corners and Led's,10,000 K HID Low-Beams, GT-R Cat-Back Exhaust System,Racingline performance moto mounts inserts, power slot rotors and hawks.Eclipse 4 channel amp powering Alpine Type-S speakers, 93 oct tune, GM HSRK, RaceineLinePerformance Ground Kit.
