How to Remove G6 Coupe Tail-lights.
1) Remove your crap and cargo nets or push them to the back of the trunk.
2) Remove the two cargo net attachment points closest to the rear.
3) Pull back the trunk carpet until you can see all 3 bolts for the tail-lights.
4) Use a 10mm socket on the 3 bolts. Be careful not to loose any of the bolts behind the carpet when they come off.
5) Gently pull the tail-lights off. It may help to push the screw(#3 from previous pics) that is closest to the slender end of the tail-light from the inside.
6) Unclip the power wire.
7) Tada! You'r tail light is off.
To put it back on, do the steps in reverse...duh!
9) But I suggest a tinted tail-light from Chad of Unique Coatings
