Hey guys, figured I put a how to after I posted a youtube video of the 6 with the sound sensitive glow sticks. Here goes nothing sorry not the best at giving instructions.
*Edit PS nightfire also did a how to on this Just realized before i did the Write up so two good ways to do it. Here`s his viewtopic.php?f=22&t=30984
Here's what you'll need
1 Sound sensitive strobe bar lights at Auto Zone
2 Pair of Scissors
3 Double sided decal tape
4 12 V dual socket extension cord
Place the dual socket extension cord in the glove box and run the wire via the passenger side fuse box.
Keep running the wire heading to the car power socket just above that fuse box. You'll have to squeeze it in as you get closer to the power source. Tuck under the air bag lights and stretch to plug in.
Next Take the passenger side strobe bar attach the double sided tape to both ends and mount under the dash. Then Run the wire into the glove box and connect. Use a tie clip to wrap up the excess wires.
Next Get the second strobe bar and do the same with the double sided tape for the driver side. Mount under the dash be very careful with this one the best spot is closer to the front of the dash and away from the pedals. This one is a pain because if it does not mount properly it will fall out especially during hot weather.
Then take the cord run through the fuse box to the glove box keep both sides of the fuse boxes open so that you can see where you are running the wire. Connect to the extension cord in the glove box and again use a tie clip to secure any loose wire.
Close up the fuse box, glove box and power up the power socket. Adjust the bass sensitivity and and start rocking.
[youtube:2tals6pe]http://www.youtube.com/watch?v=NWNLyxQAE2U[/youtube:2tals6pe]
2 Pair of Scissors
