This is the how to on replacing the stock serp. belt with a shorter belt for running at the track. It bypasses the power steering,ac and one idler puller.
Remove the maf and the small strut shock form on the left side of the motor for easier access to the serp. belt if you like. Then use a 1/2 rachet to move the belt tensioner and remove the stock belt. Make sure you pay attention on which way the belt is run so you know. Get your new belt and install it the same way as my drawing. 15-20 minutes to install.
This is stock
This is with the new short belt
New belt belt number 610K6 (duralast) and I got this belt from autozone.
This is stock
