first thing to do is to remove the airbag as shown in this thread
viewtopic.php?f=29&t=431
after the airbag is off you will have to remove the silver trim on the right side of the wheel by undoing the screew circled in red and pushing the trim the direction of the arrowin the below picture. you will also have to remove teh cruise controls on the other side (remove the same way) to be able to undo the wires. remove the wires from the cruise control switches and from the SIR coil (the green arrow) plug in the new wire harness into the controls and plug it into the SIR coil. reinstall teh air bag and make sure everything works. NOTE the buttons will work but will not work correctly until the next step is completed at the dealer.
you will now need to take the car to the dealer and get them to change the options in the radio to tell it it has radio controls option code UK3.
on the off chance that the dealer doent know what to do these pictures are an exact walk through with the higlights as the option to choose.
first you have to build the vehicle (my vehicle shown yours may be different)
note this says"diagnosis"
note this says "Z"
note this says "Body and Accessories"
note this says "entertainment"
note this says"Module Setup"
note this says "radio"
at this screen you will have to have your speaker option codes entered in(monsoon shown)
this is the option for the radio controls
after hitting that it will reconfigure and then say process completed. once that is displayed you should be good to go
note this says "Z"
Not his but this is what it will look like.
