Ok fellas and ladies im gonna try to write up a how to on the upper grills. If there is anything else needed or questions just ask and i'll try to answer them
----FACTORY GRILL painted with bottom marks shown
----OUTSIDE COVER OF GRILL (CHROME)
To take this off without damaging your car visibly i would advise to put tape on the car if you want and use a new playing card. Also once you get a small flat head in between the cover and the car, pry it toward the chrome(just to clarify: pull handle of screwdriver toward the chrome) not the car, as it will push paint in a smudge(if you pry toward car, if you pry toward chrome shouldnt do any damage).
You will notice by the pictures where the clips should be and i would start with the other edge first, then you can pull a little and it will work itself off the rest of way. If you have problems with this use the flathead to help get rest of clips out, again pry toward chrome as if it does leave mark it will be behind trim instead of on bumper!!!!!
----INNER GRILL
Once you have chrome off this is what you will see. You can see the 4 clips for the inner grill. Start with the bottom one, pop it out with flathead screwdriver and it will almost fall the rest of way out. Shouldnt need but to take the one clip out and you can wiggle to get rest if needed.
HERE IS CLIP UP CLOSE, THIS IS THE OUTER CLIP
And that is it.
----INNER GRILL
And that is it.
This was the the prototype Figure grills. oh well long gone now
