Allllrighty all you guys who ordered the white face gauges are you ready for this...The how to on removing the cluster bezel WITH PICS!!
Step 1: Unscrew 2 T15 screws from the top of the bezel and gently start working it untill you get to the bottom of the bezel. Next, take a screw driver and pop the lower 2 corners out (only spot with acctualy clips) and pull the bezel out. The top half cover of the steering wheel column will come off with it just so you know. You don't even have to unscrew the screws on the underside of the column cover but can if you want!
This is honestly all you need to do in order to get the bezel off, I started ripping apart the lower part of the dash and all kinds of things thinking the bezel was screwed on but trust me its not. Takes about 5 mins if that to get off and you see the 4 screws that hold the cluster in place
