This is very easy to do only reason it took me 20 min to figure out is because it was dark lol
Tools needed: A small standers screwdriver.
First: Remove the battery cover
Second: Remove the clip holding the windshield washer filler neck in using the screw driver, and then just pull it out.
Third: locate the Red clips on the 3 harnesses and pull them up.
Forth: Press in the black tab just above the red clips and pull up on the lever. The easiest way is to push in with your thumb and use your pointer and middle finger to lift up.
Fifth: Once the lever is all the way up just wiggle the harness off, once all 3 are out just pull the ECU out. You can also pull the ECU out with the harnesses attached then taken them off just be careful not to pull on the wire to much.
When reinstalling make sure the 3 harnesses don't bunch up underneath where the ECU sits or it won’t seat all the way down.
