This is how you re-aim the foglights a little higher so that you can acctually get some use out of them. Once you do this you should notice a difference in the amount of light that you can see from them. This is a really easy thing to do, all you do is take a 4mm allen key and place it in the hole directly above the foglight (see picture). The easiest way to do this is park infront of a wall, garage door, house, etc.. do one at a time untill you think you have them where you like try a little at a time untill you get them where you'd like too. Finding the adjustment screw can be a little tricky but not to bad, just gets annoying for a few haha
These are just the foglights, but the driveway is raised up but you get the idea, they are a ton higher than the stock setting. Once you do one you'll see how low they really are!
