Originally posted by scuba264
So you have to look at what the cross section of the pipe is at the those bend, because that's all the flow you will actually have. If you use a 2.5" pipe and put a 90 degree bend into it, chances are that you end up with +/- 2". Now, 2" is better than the (real) stock, which is around 1. 75" you have now. The other thing that comes into play is, where ever these (non mandrel) 90 degree bends are, they tend to create a bit more turbulence within the pipe. Turbulence effects the flow in a negative way.
The issue here is not how much you spend, but rather what are you really getting for your investment.
Personally speaking, if you're on a tight budget, I would just get rid of the resonator, and install the nicest exhaust tip you can. This will give you a little louder note, plus make the car look way better.
