Eagle Eyes Dual CCFL Halo Projector Headlights
  • Re: Eagle Eyes Dual CCFL Halo Projector Headlights
    Originally posted by coulomjo View Post
    I'm not sure if that was answered before but I noticed that the EE also use big twist caps in the back like the stock ones have. Are they swappable? I'm asking because since I've already made holes in my stock ones for the HIDs I wouldn't have to on these ones
    They are however the stock caps are a slightly tighter fit on the EE lights but mine worked and sealed no problem.
    Mods: GT-R exhaust, CRABs O3 w/FPU, 35% tint, 5000K HID lows/fogs, upper/lower recessed grilles, Racingline strut bar, concept darts, white LED map/dome/mirror/trunk/license/reverse lights
      Nice! Thanks for the info.
      COULOMJO - 2006 G6 V6
      Clicky for progression place
      CURRENT MODS: C.R.A.B.S. (O3), 20% Tint, Upper & lower recessed grilles (black), LEDs (dome light, trunk, licence plate & reverse lights), DRL delete, intake resonator delete, Dart & trunk keyhole overlays, debadge, '09 Stock radio (with AUX IN), '10 HVAC controls, Hood quicklifts, Eagle Eyes black projector headlights, LED brake/turn lights (including 3rd brake light LED retrofit), Pioneer speakers (front & back), Bazooka BTA8100FHC 8" Subwoofer, Hidden 12v adapter (that turn on with the ignition), EE Halo DRL bypass (How-to).
      MODS - COMING SOON: None... for now!
      Also in the parking lot: 2008 Pontiac Torrent "Podium Edition"
      My first G6 - Lease ended - but not forgotten
        If you delete the DRLs (fuse & relays) will the halos still light up during the day ?
          I removed the fuse but not the relay and mine work just fine.
          2008 G6 GXP 3.6L Coupe - Street Edition - Black
          Mods: All the usual suspects
          Progression Thread
            my replacement Revotec EE's came in the mail tonight. The incdient on the 27th destroyed my right side EE housing. so I needed to order a new set. The DDM HID's are fine though so it's all good.
            Performance: WAMS, K&N 69 Series CAI, Custom Magnaflow Exhaust built with a Camaro SS Muffler and Glasspack with 4 inch double-wall stainless steel tips, Thunderbolt 8.2mm High-Performance Spark Plug Wires, NGK Laser Iridium Spark Plugs, Pennzoil Ultra Full Synthetic, Resonator Delete, Racingline Motor Mount Inserts, Racingline Grounding kit. (4 additional grounds from battery to front bumper for DDM tuning HIDS)
            Handling: Moog Front Control Arms and Toe Ends, Racingline STB, Koni Yellow "4 Point" Suspension -Front to Rear- , Energy Suspension Poly Front Sway Bar bushings, Energy Suspension Tie-rod bushings, Energy Suspension Front Control Arm replacement mounts, Eibach Pro-kit springs, BMD Front Endlinks, Genuine Saab .9mm Rear Chamber Shims, 19mm Motorsports spacers on all 4 tires.
            Stopping: Cobalt SS Front Brembo's, R1Concepts Premium Cross-slotted Front Rotors, R1Concepts Premium Cross-slotted and Drilled rear Rotors, Hawk HPS pads, ATE Super Blue Brake Fluid, BMD Steel Braided Brake Lines, Michelin Pilot Sport A/S 3 tires.
            Appearance: Revotec Eagle Eye CCFL Projectors, Red Calibers, 6000k 35w DDM fogs, 6000k 55w DDM lows, LED Taillights, DDM Tuning LED Switchback Turn Signals, Konig Crown 17x7.5 Rims. 30% tint in front windows, rear windows @ 15% tint
            Safety & Security: Cobra XRS 9470 Radar Detector, Experimental 2mm rear mounted camera with Bluetooth connectivity to my phone, GOSHERS Universal Blind Spot Detection System w/ LED Indicators, Waze GPS App with a windshield mount for early warning for police coupled with Radar Detector (double-whammy).
            Experimental: BG 44k, BG MOA, BG ATC, Custom Transmission Cooler, Super Secret Flux-capacitor transporter, Header reflective wrap, CAI 2000 degree radiant reflective wrap.
            Progression: http://www.g6performance.com/forum/s...ad.php?t=22823
              Eric,
              I just ordered these and I'll see if this helps for me.
              I just think my ground wire is too small with the relay's I'm using, these relays appear to use a thicker gauge wire. It's never the lead ground wire from the bumper that melts it's the smaller guage wire from the relay that appears to be the fault. so hopefully this will fix my issue. The relay's I've been using are there cheap ones from Home Depot. So hopefully, just hopefully, these higher quality ones will solve my issue.
              MY other big issue is that there isn't any place to really tie down those relay's once there hooked up. I think when the water splashes in the fender is gets into that cavity where the resonator used to live and it get on the relay's and gets them wet. I'm almost wondering if I need to wrap them in a plastic bag and shrink-wrap them.
              I'll keep you posted.
                Alright, you guys convinced me. I placed my order this morning.
                  So here's the story behind mine. I bought mine on craigslist for really cheap, thought i was getting an awesome deal. Until the fog. The passenger side headlight fogged up badly, and there was a visible puddle of water in the bottom of the housing after the first rain.
                  I tried to seal them up using an epoxy. However, the leak was too bad. I ended up accepting the fact that I got p'owned out of $150. A couple months flash-by, I'm about to buy a brand new set from SaberSport. And ask if it's possible to just buy one. I explained my story up to this point to him, and he was extremely sympathetic. Even though I did not buy them from their company, they offered to replace them for free. I paid shipping both ways, but yesterday in the mail I received a brand new set of Eagle Eyes.
                  The inside halo of the new headlights was very dull at first, and I was getting worried about it. So I called sabersport back, and they said just let them run for a week or so. Sometimes the CCFL's need time to warm up. Less than 1 hour later, it was up to full brightness.
                  I HIGHLY recommend this product, and highly recommend SaberSport. This is my all time favorite G6 mod. You will not be disappointed.
                  -If its the money that scares you, trust me, they're worth it.
                  -If you don't like the black housing that everyone seems to have, look deeper, they make a stock-clean chrome one.
                  -And if you think you like the sypders better, stop lying to yourself.
                  DGC393's Progression
                  Mods
                  Performance:
                  1.CRABS with K&N Cold Air Filter
                  2.RES Delete
                  3.Variation on Lampoon's RAM Air
                  4. Pennzoil Ultra Full Synthetic
                  5.Full Catback Stainless Steel Magnaflow Dual Exhaust
                  Appearance:
                  1.Rebadged/Debadged- GT Delete, G6 to trunk, Pontiac to dash
                  2.20% Window Tint (All windows)
                  3.Upper Recessed Grilles
                  4.Lower Recessed Grilles
                  5.Upgrated G6 embroidered carpets
                  6. Temple and G6P Stuntin'
                  7.Tinted Tail Lights (reverse blocks white)
                  8.Fog lights ever on
                  9.Tinted emblems
                  10.Pontiac seatbelt pads
                  11.Pontiac logo tire caps
                  12.Eagle Eye headlights (black bezel)
                  13.Eibach Prokit
                  14. Color matched, AIT Fiberglass Hood
                    I pulled my drl fuse and they don't automatically light up during the day. I had to flip my parking lights on or my fogs on for them to come on.
                      Awww. Makes sense given the wiring available. I really want to use them as DRLs but I don't want my lows to light up in the day.
                      Has anyone tried to re-wire them?
                        Alright so I just got my headlights tonight and I installed them... but I found out that both didn't fit properly! If I push them in to put the screws in they have a huge gap underneath... and also where they meet the fender it doesn't look right... as if the lens wasn't pushed in enough...
                        Anyone had these issues?
                        EDIT: It's really cold out here and tomorrow will be the coldest of the winter (-36C / -33F) and I did install them at night... I'll try to have a better look at them this week-end.
                          Cool, thats par for the course on the EEs. Its not horrible but it is visible. im thinking of putting weather stripping under it.
                          Death,
                          Since I had already ordered the bypass harness from DDM i went ahead and installed it. so far so good. we will see if it holds up.
                          Progression Thread
                            Death,
                            With my Guard Rail incident that happened on the 2nd of this month my car has been at the collision shop getting the whole right side from the front fender back to the rear fender re-done; I pick her up tomorrow I can't wait (I paid the extra $60 to have them repaint the whole car). About a $3800 insurance claim nothing structural just cosmetic (I told the insurance guy I paid 375 for the EE's so he knocked that much off the $500 deductible), I was only going 6 mph when I hit black ice and slide into the guard rail. Ironically if I hadn't lowered my car 3 week earlier it could have been worst....
                            But I had to order new EE's as-well since the right side unit crack upon the impact on the guard rail. The shop installed them but not the HID's, I have to swap the screw caps on the rear of the lights. Before I brought them to the shop both HID'S on the left and right still fired so it shouldn't be hard to get them installed.
                            I've missed my baby, driving this Enterprise Chevy Traverse (GEICO rules) this month hasn't been the same...
                              Yea man, i couldnt imagine a month, thats horrible. i have to have the bumper redone on mine soon too from a fender bender. they better have it back in a week damnit
                              Progression Thread
                                So I've been running these for a week now, and they are awesome. However there have been some hiccups along the way:
                                The first time I installed them I had a gap underneath so I didn't screw them in like usual. This resulted in a big misalignment on the sides:
                                Yesterday I took them apart (Passenger high beam wasn't working, turned out the negative wire wasn't plugged in) and I reinstalled them "the proper way". The alignment is fine now on top & sides, but I have a gap underneath.
                                It doesn't show too much from afar
                                However sometimes one of my halos doesn't get to full power (always the same one)... is that normal? I read other posts that says it can take some time and the cold surely didn't help... Guess I'll wait another 1-2 weeks before worrying?
