I figured I'd start making a progression page.
Below is a list on current mods:
Performance:
1. R1Concepts Premier Carbon-Fiber Cross-slotted and Drilled Rotors
2. Cobalt SS Front Brembo's with Hawk FFF grade pads (nearly as tough as the carbon rotors, 9 months and haven't even worn!)
3. Racingline STB
4. K&N 69 Series CAI [COLOR="#FF0000"]
5. NGK Iridium Plugs
6. Pennzoil Ultra Full Synthetic
7. Resonator Delete
8. Michelin Pilot Sport A/S 3 tires
9. BMD Front Endlinks
10. Racingline MMI
11. Racingline Grounding Wires
12. Energy Suspension Poly Bushings
13. Eibach Pro Kit
14. Custom Magnaflow Dual Tip Exhaust
15. ATE Super Blue Brake Fluid
16. HPS Hawk Pads (F/R)
17. BMD Stainless Steel Brakes Lines
18. Switchback LED in EE's.
19. Twin Custom-made Transmission Cooler ~ 15 degrees cooler than stock
20. Koni Yellow Adjustable Sport-tune Front Inserts (Cobalt SS)
21. Koni Yellow Adjustable Sport-tune Rear Absorbers (Saab 9-3)
22. WAMS ECM/TCM Tune - 93 octane baby!
23. Wheel Spacers - 22mm front, 22mm rear.
24. MPD1 Ram-Air Hood, functional into CRAB
25. Jet Performance Throttle Body - 85mm bore
26. Custom Rear-Sway Bar
27. Heat-wrapped Intake and Exhuast manifold
28. 68mm Rear Wing Spoiler
Appearance:
1. Revotec Eagle Eye CCFL Projectors
2. Red Calibers
3. 6000k 35w DDM fogs
4. 6000k 55w DDM lows
5. LED's in brake lights.
6. Konig Crown 17x7.5 Sport Series rims (only weight 10 lbs each compared to the 18 lbs of the stock rims)
7. 30% Tint all the way around, 15% tint in rear window.
Safety:
1. Radar Detector - Cobra XRS9570
2. 2mm Rear mounted rear camera.
3. Blind-spot Detection system
Future mod's on the road map:
1. Roof and Window Deflectors
2. LED in vents (red)
3. Metal grated pedals.
4. Amber LED blinker on Side Mirrors tied into signals.
5. White LED Strip on grille (like of the white LED strip on most Benz's)
I'll update this list as mod's are finished.
Performance:
3. Racingline STB
7. Resonator Delete
10. Racingline MMI
13. Eibach Pro Kit
Appearance:
2. Red Calibers
Safety:
