anyone try this ipod adapter?
  • This thing works reallly well, but now I can't get it to switch back to XM.
    Any ideas?
    http://www.cardomain.com/ride/2543500/1
    • Originally posted by Earl Poe
      Any ideas?
      Same here. I think in order to get your XM to work, you need to hook up the black relay they give you. Unfortunately, they don't give very good info on how to hook it up.
      • I think you have to press "6" or something....assuming you have the relays and everything hooked up.
        • Yes, by pressing "6" you can switch back and forth between XM & Ipod. But all of a sudden it doesn't work anymore. I'm stuck on Ipod and can't get back to XM. Tried discontecting the Ipod and disconnecting the negative on the battery. Still not right.
          • Can someone please tell me what specific wires need to be attached to the black relay for a stock stereo with XM? The directions they give are incredibly vague.
            • ugh
              i saw the video clip, but xm blah blah.. i dont have xm in mine! damn i hate fm modulater!!!
              "monsoon w/ no xm single CD" is what i have
              06' Black G6 GT Coupe: FL legal tint, GT-R Exhaust, Black Emblem Overlays, Silver G6peformance Decals, CAI coming soon...
              • The YELLOW wire coming off of the black relay gets spliced to the RED wire coming out of the XM tuner unit. The BLUE wire coming off of the black relay gets spliced to the other half of the RED wire, which runs into the car. The Ipod connection just kind of acts as a splice in the middle of the RED power wire. Hope this helps you.
                • does this thing work for ipod shuffle (the clip-on one)?
                  You're doing it all wrong...you gotta cup the balls, relax the jaw...
                  • From the auction:
                    This interface is compatible with the following iPod's through the bottom dock connector:
                    NANO (ALL MODELS)
                    VIDEO (ALL MODELS)
                    PHOTO (ALL MODELS)
                    MINI (ALL MODELS)
                    G3 (3rd GEN)
                    G4 (4th GEN)
                    The Present: 2010 Mazdaspeed3... Zoom Zoom
                    The Past: 06 G6 GTP Vert: Westers Tune - GT-R Exhaust - Doc's Stage3 CAI+ CRAB O4+K&N - GMPD Strut - RL Street Inserts - CMS Bespoke Vert Lowering Springs - Quicklifts - Enkei FN18's, N3000's 245/45y18 - 35% Tint Around - 4300k HIDs His & Los - Black Headlight bezels - Black Recessed Grills - Pooners Chrome Trim Blackout - Black Overlays on Darts - Avic f700bt
                    • After having it installed at a GM dealership, I paid $90 and it didn't work. The I pod would charge but not be recognized by the radio.
                      I finally took it back to another GM dealer and they said it was simply that the T tap to the radio wasn't spliced through the wire enough. All they did was tighten it a little and now it works. So if anybody has the same problem, there's your fix.
                      It works and sounds GREAT, the only problem is the sun roof is still leaking and now I think the cars going thanks to the Lemon law.
                      2006 Pontiac G6 GTP
                      Stock Silver 3.9L Coupe
                      "A bad day at racing is better then a good day at the office"
                        Mine has NEVER worked with the "6" button. Only way I can switch between XM/iPod is cycle through the bands: FM1 > FM2 > AM > XM1 > XM2 > FM1 > FM2 > AM > iPod > iPod > FM1 > etc...
                        Annoying as hell and I'm going to just rip the damn thing out as soon as I have a day off...I'm done with it. Has never worked right since day 1. Going to hold out for the GM interface...
                        2009 PONTIAC G8
                        MAGNETIC GRAY METALLIC
                        • Originally posted by ragingfish
                          Wow, you're much more patient than I was. I had it connected for about an hour before ripping it back out.
                          • Originally posted by joresnik
                            It worked as it was supposed to (sans the #6 functionality) for about a month or two. Now it's just being a piece of shit.
                            2009 PONTIAC G8
                            • selling it cheap anyone?
                              • Will this work on 2007 models? Also is the AUX compatible with a zune?
