This is a quick and easy mod, and will cost you less than 10$ if you already own Eagle Eyes headlights!
Before
Halos do not turn on during the day
Halos light up with side LEDs & parking lights (i.e. remote start, night time)
Halos turn off immediately when the car is stopped
After
Halos turn on immediately when the ignition is on (day & night)
Halos DO NOT light up with side LEDs & parking lights (but does turn on with remote start)
Halos turn off after 5-10 seconds when ignition is turned off.
What you will need:
- A pair of EE projector headlights
- 10A mini fuse
- 1 Add-a-fuse kit
- Electrical wire (10ft is more than enough)
- Long nose pliers
- Wire strippers
- Tie-wraps
- Electrical tape
- 7mm socket (not shown on picture)
- Flat head screwdriver (not shown on picture)
Here's a closeup of the Add-a-fuse kit
Instructions:
Step 1
Remove headlights: Open hood, remove all six push-pins with flat head screwdriver located over the upper grilles. Then unscrew all four screws (two per headlight) with the 7mm socket. Wiggle out headlight. (Headlight removal help here).
Step 2
Disconnect the brown/red wire from the headlight. It is located between the main headlamp connector and the halo converter. Put electric tape on the male end (brown, from the main connector) to protect it and secure it with a tie-wrap. Repeat with other headlight.
Step 3
Attach together two wires and secure them into the Add-a-fuse kit. You will need to crush the blue connector to secure the connection in place. Wrap in electrical tape for weatherproofing.
Step 4
Run both wires from the fuse box to each halo converter (I twisted the wire around the female connector of the red wire & used electrical tape to secure everything). Make sure to give yourself some wiggle room at the fuse box (see image below). Make sure they clear any moving parts or heat sources! (I followed my HID relay harnesses over the radiator)
(In this picture I've disconnected the brown/red wire and connected my wire from the fuse box to the female/red wire connector of the halo converter.)
Step 5
Remove battery cover & fuse box cover. Find a fuse that is only powered when the ignition is ON. Initially I had used #6 but for some reason the halos would stay on sometimes. I reccomend using #16 (PCM IGN 1) (works flawlesly). Make your way through the top of the box with your wire (you may need to cut a little opening to let the wire out, otherwise the box cover won't snap in place properly).
Location of FUSE #16 (PCM IGN 1)
Make your way to the top where the positive is connected to the fuse box. It's the only place your wire can come out of the box once the cover is back in place.
Step 6
TEST YOUR MOD before putting everything back together! Make sure your halos don't light up when the ignition is turned OFF. If they are ON while you have your keys in your pocket then you are using the wrong fuse. Insert your key into ignition & turn it to ACC. All four halos should turn ON. When you remove you key they should turn off instantly.
Step 7
Secure your wires with Tie-wraps. Put back fuse box & battery cover. Reinstall headlights. Re-test to make sure everything still works!
Step 8
Enjoy your mod!
08-28-2013 - EDIT - The halos do turn on with remote start when using fuse #6. I've updated the "after" section.
11-04-2013 - EDIT - After verification the fuse I used is #6 and not #47. Thanks justeric78!
11-08-2013 - EDIT - Changed fuse #6 (EMISSION) for #16 (PCM IGN 1). After testing #16 works perfectly (Halos sometimes stays on with #6 and could drain the battery). Picture updated to locate #16
Before
After
What you will need:
- 10A mini fuse
- 1 Add-a-fuse kit
- Long nose pliers
- Wire strippers
- Tie-wraps
- Electrical tape
Instructions:
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Enjoy your mod!
