3.5L headers
  • #31
    Re: 3.5L headers
    Originally posted by GTPprix View Post
    Tuners are not the same as software engineers, almost all speed shops have tuners I only know of like two that have actual software engineers in house So far that place looks like all imports? Some sweet GTR's on there though!!!
    Indeed, I went to the shop yesterday, it's about a 1:30 minute drive from my house. They've done tunes before on G6's and they have dyno tests to prove it with pictures. (what surprises me is that no one on here has ever reported a successfully turbo, so it was interesting) I've already locked in $350 to install the headers (I saw someone one here put them on their 3.5L and I will order the same kit) and they will get back to me by the end of the week for the quote for the turbo. I told them to give me about 3 weeks to get the headers ordered and they said that's perfectly fine.
    What's interesting is they suggested putting my turbo in the rear, which seems kind of crazy but I guess it's possible....
    Performance: WAMS, K&N 69 Series CAI, Custom Magnaflow Exhaust built with a Camaro SS Muffler and Glasspack with 4 inch double-wall stainless steel tips, Thunderbolt 8.2mm High-Performance Spark Plug Wires, NGK Laser Iridium Spark Plugs, Pennzoil Ultra Full Synthetic, Resonator Delete, Racingline Motor Mount Inserts, Racingline Grounding kit. (4 additional grounds from battery to front bumper for DDM tuning HIDS)
    Handling: Moog Front Control Arms and Toe Ends, Racingline STB, Koni Yellow "4 Point" Suspension -Front to Rear- , Energy Suspension Poly Front Sway Bar bushings, Energy Suspension Tie-rod bushings, Energy Suspension Front Control Arm replacement mounts, Eibach Pro-kit springs, BMD Front Endlinks, Genuine Saab .9mm Rear Chamber Shims, 19mm Motorsports spacers on all 4 tires.
    Stopping: Cobalt SS Front Brembo's, R1Concepts Premium Cross-slotted Front Rotors, R1Concepts Premium Cross-slotted and Drilled rear Rotors, Hawk HPS pads, ATE Super Blue Brake Fluid, BMD Steel Braided Brake Lines, Michelin Pilot Sport A/S 3 tires.
    Appearance: Revotec Eagle Eye CCFL Projectors, Red Calibers, 6000k 35w DDM fogs, 6000k 55w DDM lows, LED Taillights, DDM Tuning LED Switchback Turn Signals, Konig Crown 17x7.5 Rims. 30% tint in front windows, rear windows @ 15% tint
    Safety & Security: Cobra XRS 9470 Radar Detector, Experimental 2mm rear mounted camera with Bluetooth connectivity to my phone, GOSHERS Universal Blind Spot Detection System w/ LED Indicators, Waze GPS App with a windshield mount for early warning for police coupled with Radar Detector (double-whammy).
    Experimental: BG 44k, BG MOA, BG ATC, Custom Transmission Cooler, Super Secret Flux-capacitor transporter, Header reflective wrap, CAI 2000 degree radiant reflective wrap.
    Progression: http://www.g6performance.com/forum/s...ad.php?t=22823
    • #32
      Re: 3.5L headers
      Originally posted by Deathmage View Post
      Indeed, I went to the shop yesterday, it's about a 1:30 minute drive from my house. They've done tunes before on G6's and they have dyno tests to prove it with pictures. I've already locked in $350 to install the headers (I saw someone one here put them on their 3.5L and I will order the same kit) and they will get back to me by the end of the week for the quote for the turbo. I told them to give me about 3 weeks to get the headers ordered and they said that's perfectly fine.
      Its because its easier, loses a bit of efficiency but its easier to install and setup that way. Tuning G6's in general isnt impossible its the 05/06 thats the problem but your stuff says 2008 so you should be ok
      Chris White
      http://www.GTOShiftLight.com
      2006 Spice Red GTO - Stock
      2012 CTS-V 1 of 57 Custom IPC/BCM/Radio Corsa/LPE CAI
      2012 Cherokee SRT8 - Stockish
      2013 SRX - Custom IPC, BCM and CUE
      2013 XTS Platinum - Custom IPC
      • #33
        Re: 3.5L headers
        What's interesting for me is the 2008 engine that I have in my G6 was made in 2012, lol! .... might explain why I get 35.6 MPG on the highway on cruise.... just a FYI, my original engine got hydrolocked at 38k (91k now)
        • #34
          Re: 3.5L headers
          Cant beat a fresh engine man!!!!! My only concern with that (and this is pure conjecture) is if you did a top to bottom swap IE did the 2012 come with injectors and everything or did you swap those off your 08?
          Chris White
          • #35
            Re: 3.5L headers
            Progressive at the time (Hurricane Irene) since I had a 100k warranty decided that the engine should be replace brand-new. It was installed at the dealership, so I'm going to assume all the right pieces are in her, lol. Although when I did the Energy Suspension sway bar bushings, I found my sway bar is the size that is suppose to be in the G6 GXP, so it's not out of the realm of possibilities..... to my knowledge everything is new, they ordered new injectors and everything, the whole engine was taken apart for insurance reasons.... metal shaving all over the place.
            • #36
              Re: 3.5L headers
              The only reason I ask is there was a small injector change I believe either after or during 2008 (I'd have to check) but it may skew your fuel economy readings if they did the whole thing pan to intake with the newer injectors. Not a huge deal just something to ponder
              Chris White
              • #37
                Re: 3.5L headers
                Could this mess with a tune since the MAS on the intake could be skewed?
                Doh! - I just a email they said they won't do the tune - looks like you locked in another one! - They are however still doing the headers. (which these headers, exhaust and CAI, she is just screaming now for a tune, )
                • #38
                  3.5L headers
                  Yes it could I'd be curious what injectors it actually has to make sure we can get the tune straight
                  Chris White
                  • #39
                    Re: 3.5L headers
                    Well this weekend I'm doing a seafoam and changing my plugs/wires. I could see if there is some labels someplace on the engine, perhaps I could find out for you....
                    • #40
                      3.5L headers
                      Take pics of the injectors and see if you can find an eight digit part number on one.
                      Chris White
                      • #41
                        Re: 3.5L headers
                        Very well. From the looks of my progression I'll probably order your tune mid April - early May. I just wanted to get all of the stiffer engine mounts and suspension installed before your tune, just so I can feel and handle the increase and so she wouldn't fall apart from all the stock crap, lol.
                        • #42
                          Re: 3.5L headers
                          I am not knocking your abilities to tune it but saying the its a ridiculous amount of money to tune headers. But this is the place I am going to http://www.doneriteautomotive.com/index.html
                          8000k hids, interior paint, tint 35 front/ 20 back, tinted tails with pontiac symbol, blacked out headlights with black eyelids, red grille lights, racing stripes, interior neons, 2- OZaudio 10 in subs, 1800 watt kenwood amp, 17in XXR-001, intake, custom exhaust, painted engine cover
                          • #43
                            Re: 3.5L headers
                            Its what it takes to do small changes on this controller, also the main reason I almost never do them for that controller. IF software existed for this controller $450 to MAYBE $600 would be in the ballpark $850 is insane. Just verified they use HP tuners which does not (nor does any of the other brands they sell) have the ability to do squat to your PCM.
                            Oh and anyone that advertises this as part of their "tuning" uhhhhh.... "Change Knock Sensor Settings"....
                            I"m not trying to be a dick it's just I've been dealing with this scenario for years and it sucks LOL
                            Chris White
                            • #44
                              Re: 3.5L headers
                              hey chris would i be straight without a retune if i got new headers?
                              http://www.g6ownersclub.com/forum/sh...ad.php?t=13376
                              v^v^my progression^v^v
                              http://www.g6performance.com/forum/s...ad.php?t=24215
                              • #45
                                Re: 3.5L headers
                                No, not if they are worth a damn.
                                Chris White
