Originally posted by Blackrider
2015 Chevy SS, Perfect Blue Metallic, Sunroof, No Spare, M6
Appearance: Full LED Conversion, 6000L D3S HID Bulbs, Holden Rear and Front Embloms
Go Stuff: Diablew 93 Octane Tune
Missed and not forgotten. Traded.
2005 CGM GTO.
386whp, 364ft-lb torque, Corsa Sport Exhaust, Tuning, K&N Intake, VX Tails, Halo Projectors
2009 G8 GT SRM Premium Package, 6000K LED + HID Lows, Factory Bluetooth Retrofit, Atari Gauges, Factory iPod Control, 93 Octane Diablew Tune, Vararam Intake, MBR Strut Bar, Corsa Catback, DBA 4000SX Slotted + Drilled Rotors, Hawk Ceramic Pads.
Originally posted by WoodburyManOriginally posted by BlackriderThats overkill, there is no need for "true Dual" exhaust on any of the G6's engines.2009 Panther Black G8 GT
334 WHP 347 WTQ
GM CATBACK EXHAUST
I was thinkin about purchasing the catback exhaust system thru gmpartsdirect in the next few weeks for my 3.6. My last two cars I tricked out with apperance mods and I'm kind of leaning away and want to start some performance mods. I need opinons is the system worth the money or not?
Re: EXHAUST!(Any Info or questions post here)
Originally posted by BlackriderOriginally posted by StacyI was thinkin about purchasing the catback exhaust system thru gmpartsdirect in the next few weeks for my 3.6. My last two cars I tricked out with apperance mods and I'm kind of leaning away and want to start some performance mods. I need opinons is the system worth the money or not?Born: 2/16/2007 -- Best Time: 14.20 @ 98.61 MPH -- 240 WHP & 205 WTQ -- Blueprinted and Balanced
- U.C. Tinted Tails - Dr. S Stage 3 - SRC Dyno Tune - Eibach Pro Kit - C.I. FPU - Scuba's Aux. Retrofit -
- 08 SS/TC Brembo Conversion - Ported Heads & I.M - MACE I.M.S. - RacingLine MMI - O.T.T.P. SRS -
- MMS Headers - ClassicPerformance Exhaust - Powerbond UDP - CF Catch Can - Racingline Strutbar -
I had another problem with my exhaust yesterday. I have the GT-R for those of you that don't know... and I put it on myself with my cousin.
Background: Put it on in October, had rattling noises while doing sharp turns when I was giving it throttle. Turned out to be exhaust. Late December, down pipe pops out of the muffler. I fix it quick, pops out a week later. I use a few long 2x4's and knock the pipe into each other a lot deeper than I originally had it. I tightened the clamp as tight as I could get it as well and all was well. The noise while turning disappeared as well. Good for almost a month.
Yesterday: I noticed on my way somewhere it was making the rattling while turning thing again. The damn down pipe and muffler became disconnected again on my return trip and I fixed it again.
Any suggestions on what I should check, and why it might be popping out like this every so often?2015 Chevy SS, Perfect Blue Metallic, Sunroof, No Spare, M6
2005 CGM GTO.
are you moving the whole system or just that one pipe?
if there is something forcing pressure on that area to come unattatched might need a support to to not have that pressure right there, so for that i would think the whole system needs moved toward that area
Originally posted by WoodburyManI had another problem with my exhaust yesterday. I have the GT-R for those of you that don't know... and I put it on myself with my cousin.
I'm going to try taking it off and cleaning out the outside and inside of both pipes. There has to be salt / sand on them since that's all thats on the bottom of the car... I'll check the clamp to. Hopefully I didn't strip it.. I used a long ratchet to tighten it this last time..
Worst off I might try another bracket. My dad can get me some stainless brackets, plumbing contractor, worse off. But I wont be able to test it until next week. I'm keeping my ratchet set in the car with me just in case from now on in case something happens while I'm up at school. It's a 60 mile haul back home on the highway. I've driven home when it's come off before but not more than 15 miles or so. It would be deafening on the highway without a muffler2015 Chevy SS, Perfect Blue Metallic, Sunroof, No Spare, M6
2005 CGM GTO.
Originally posted by BlackriderOriginally posted by 2007G6DamnThank you. Is there an aftermarket exhaust for the G6 with a 2.5" or 3" diameter?
Yes the GTR system is 2.5. There is no need for 3 inch on an N/A engine.Born: 2/16/2007 -- Best Time: 14.20 @ 98.61 MPH -- 240 WHP & 205 WTQ -- Blueprinted and Balanced
Re: What is the stock diameter for the exhaust on the GTP?
