My last dealer trip went fairly well for warranty work. They rebuilt my engine because of a rattling noise on startup, put in new model visors, new radio, etc. they even washed my car!
but when I got home i started seeing the problems...they left pieces of my dash hanging off, I found a rattle on the right side of the radio thats pretty bad, rubber noise pieces on my engine cover are gone, a foam block on the passenger side kick panel isn't there anymore, a bolt is missing from my air box, a plastic holder of the firewall is gone, the next day my fenderwell fell down and rubbed on my tire and is now cracked and rubs when i turn left. then today I start my car drive to school and i'm accelerating around this turn and i hear this loud rattle like something is banging against my engine with the vibrations. at first I thought it was my engine cover but the rubber piece had been missing for months with no problem. the i took the engine cover off and there some plastic piece with tubes and cables running to it that is just hanging around loose in there on top of it's mounting bracket. (it's on the right side of the ecotec on top of the motor almost)
do you think they will take care of
-the fenderwell being damaged after the engine work? I dont know if it was coincidence or if they messed up on the reinstallation. either way will they fix it under warranty?
-all the missing bolts, rubber pieces, foam blocks....will the replace them?
-radio rattle after they put the new one in...will they fix it?
-and last time they didn't fix my driver seat squeak maybe if I show them since it does it every time i'm in the car....they told me that they couldn't reproduce the squeak.
