Only time will tell how these slotted rotor hold up..... If I get about 20k out of them I'd be happy; there only about $160 for rotors and $100 for pads, no big deal really....
Yeah I've got about 15k on my Brembos right now, rotors still look like the day I've got them, no doubt you'll be able to get a lot more than 20k on them... What pads did you end up going with?
Mods: BMD Adjustable Front End Links, BMD Stainless Steel Brake Lines, Koni Yellow Sport Dampers, Pedders Lowering Springs, Brembo Upgrade, Racingline STB, Custom Intake, 8000k Lowbeam HIDs, 10000k Foglight HIDs, Badge & Doorsill Overlays, GM G6 Logo Mats, Blacked Out Window Trim, Blacked Out Grills, Pioneer Headunit, 2 10" Kenwood Subs
Hawk HPS Street variance.
Performance: WAMS, K&N 69 Series CAI, Custom Magnaflow Exhaust built with a Camaro SS Muffler and Glasspack with 4 inch double-wall stainless steel tips, Thunderbolt 8.2mm High-Performance Spark Plug Wires, NGK Laser Iridium Spark Plugs, Pennzoil Ultra Full Synthetic, Resonator Delete, Racingline Motor Mount Inserts, Racingline Grounding kit. (4 additional grounds from battery to front bumper for DDM tuning HIDS)
whelp the other Brembo arrived as did the clips. the Rotors will be here on Tuesday.
my only question now is which one is which side, lol - I knew I should have labeled them!
Bleeders go towards the top when mounted on the knuckle, that way the air floats up to the bleeders, hope that makes sense
that makes sense!
BTW - anyone know what the offset is off the stock rims? - DTD tells me the Konig crown have a offset of 40mm.... wanting to go with 19mm adapters... will they be snug?
GTP 18 inch rims only take 5mm spacers. It's what I'm running with my brembos.
well I'm just looking to get rid of the wheel well sucked look. If I get a bit more handling that would be a plus! - braking I assume will be 50% better
7 to 10 days for 19mm spacers from Motor Sports.....
looks like I need a new right rear tire anyways, dam pothole tore up my inner skirt on the inside and it's starting to show metal.... warranty replacement perhaps. there only 4 months old!
doggie....
he's my boy! - his name is Hunter. 4 year old White German Shepard.
