Re: Install Koni Yellow Sport Dampers
Yeah second set to cut up is definitely the way to go. You can prepare the inserts before hand and then just bolt them up like normal struts when you're ready to do the install, less down time that way. Might as well repaint the housings when you have them stripped down, fend off the rust a little longer... Also don't forget red Loctite for the bottom bolt, and be sure to torque it to 55 ft-lbs, these are probably the two most important steps... How do you like the rears so far?
Originally posted by RedMoon Roku
View Post
