Widest Absolute Tire Size
  • Widest Absolute Tire Size
    I have a 2005 with stock GT wheels. I am running 225 and need the look of a fatter tire, and some more traction...
    I have seen 245/ 45/ 17 offered for my car. And some 235/ 45/17 for my car... what is the absolute widest i can run?
    Re: Widest Absolute Tire Size
    well, i have a gtp with 18s and im sure we have the same size wheel well. i have 245 40 18s on with no problem and still have plenty of clearance, but not much more. i really doubt a 255 will fit, but you can only try
      pics zave?
      [ Post made via Mobile Device ]
      "Wheel gap can be compared to a vaginaa. The more fingers you can stick in the worse off you are. "
        well, the widest id probably dare go might be a 245, i have 235's now. any wider and you might expirience some dramatic instability in turning. personally i have to be constantly wary with the steering wheel when traversing slaloms any closer spaced than 45 feet or body roll momentum will take over and make me slide in whatever direction it chooses.
        then again youre a quarter mile'r i believe? in which case i dont really see a problem with going wider perrformance wise. ive always kinda thought that getting a narrower rear tire at the same time would greatly reduce the drag cause by the rear end, hell maybe thatd be all youd have to do for the same effect as a wider front tire. i dont know much about drag racing really, i autox, but i imagine that would greatly assist the launch, right?
        '08 3.5 lz4
        Custom fenderwell CAI
        FIRST G6 TO USE COILOVERS
        Megan Racing coilovers
        Addco Rear Sway Bar
        Racingline strut-bar installed
        Racingline MMI's installed
          i run 245/40/18 and not a single problem. plus coming from 225/50/17 i have no speedometer issues.
            then again my present tires have a fat 50 profile. that might have a little to do with it :/
            luckilly a second set of rims+tires are on their way, 40 profiles, specifically for autox. that way i dont mess up my daily tires. like i have been doing
            that just what ive been though anyway. im pretty sure you could squeeze 255's on there. they just might look a little silly imo.
            '08 3.5 lz4
            Addco Rear Sway Bar
              no i'm pretty sure you cannot fit 255s. my 245/40s barely fit and any bigger will rub.
                do you have ur car lowered or would lowering it cause that size to rub?
                  It also depends on the tire manufacturer. I had F1's in 225/50 18 on my G6 and they would rub if you turned the wheel until lock.
                  2009 Liquid Red G8GT
                  4 door mafia
                  93 octane VMS ecm/tcm tune
                  8000k hid's
                  Solo Mach Shorty & HFC's
                  Rotofab cai and radiator cover
                  13.207@107.11
                  330 hp/328 tq on a Mustang dyno
                    i just meant squeeze onto the rim specifically. outside that are the other issues that come with that territory i would suppose.
                    '08 3.5 lz4
                    Addco Rear Sway Bar
                      i had 245/45 on my factory 18s
                      how wide are the other factory wheels? that is what will determine the real result here
                        i'm not lowered and 245's barely fit.
                          The wheels on a GXP for instance is 7" wide. Use this for comparrision.....http://www.1010tires.com/tiresizecalculator.asp
                          4 door mafia
                          8000k hid's
                          13.207@107.11
                            Im running 235 40 19 in the front and 255 35 19 in the rear but Im also running 9.5 inch wheels in the back with a 35 offset
                              y would you run a fatter tire in the back on a fwd car
                              Mods: Intake resonator removed GTR Exhaust 30% Tint Front 15% Back Crab Intake WAMS 93 octane tune RLP street motor mounts, Debaged, Destriped, and Dashhawk. Infinity Kappa door speakers, Kicker cvx 12, Pioneer AVH-3200 BT Deck, Kicker 700.5 amp
