Installed a Transmission Cooler!
  • #76
    Re: Installed a Transmission Cooler!
    So what I was trying to show you was these: Push-Loc fittings:
    With these fittings you use a type of rubber hose that doesn't have the steel braiding on the outside.
    You can see it's a thick braided rubber hose. You can connect one end to the push lock fitting to the aluminum hard line, and the other end to your clamp-on cooler.
    My coolers both have had absolutely no signs of leaks, my only problem area was the tap in point. But it's up to you if you want to run with this method.
    • #77
      I like the previous method a lot. I'll have to by new lines to have on stand by when i wanna go to the dealer to get a flush but it's a good method once you understand how it works. the dealer told me they wouldnt do flushes or work on my trans with that installed for liability reasons. what a bummer.
      .... but the crazy part of being told that was that the tech who does radiator work told me that it would be good for the car to install it .... no comment
      • #78
        He said it would be good or would not be good? I see no real cons unless its done wrong or you use the wrong cooler or something.
        And which method? The steel braided lines? I want to do that too, both for looks and for a permanent install
        Also I'm pretty sure deathmage got a flush at a dealer. Try calling around maybe?
        • #79
          May seem like a noobish question, but would this help for a automatic without tapshift??
          "Chaos is a name for any order that produces confusion in our minds"
          Originally posted by ThreePointSix
          Call the police. Show us on this doll where it happened...
          • #80
            .... if I don't answer does this give you your answer?
            Don't know what dealership your going too but I did my tranny cooler and told my dealership I installed a tranny cooler and they flushed it. They said it looked very nicely done and saw no problems. My dealership may-be a bit more lenient since I go there often for PM and they know I take really good care of the car....
            Performance: WAMS, K&N 69 Series CAI, Custom Magnaflow Exhaust built with a Camaro SS Muffler and Glasspack with 4 inch double-wall stainless steel tips, Thunderbolt 8.2mm High-Performance Spark Plug Wires, NGK Laser Iridium Spark Plugs, Pennzoil Ultra Full Synthetic, Resonator Delete, Racingline Motor Mount Inserts, Racingline Grounding kit. (4 additional grounds from battery to front bumper for DDM tuning HIDS)
            Handling: Moog Front Control Arms and Toe Ends, Racingline STB, Koni Yellow "4 Point" Suspension -Front to Rear- , Energy Suspension Poly Front Sway Bar bushings, Energy Suspension Tie-rod bushings, Energy Suspension Front Control Arm replacement mounts, Eibach Pro-kit springs, BMD Front Endlinks, Genuine Saab .9mm Rear Chamber Shims, 19mm Motorsports spacers on all 4 tires.
            Stopping: Cobalt SS Front Brembo's, R1Concepts Premium Cross-slotted Front Rotors, R1Concepts Premium Cross-slotted and Drilled rear Rotors, Hawk HPS pads, ATE Super Blue Brake Fluid, BMD Steel Braided Brake Lines, Michelin Pilot Sport A/S 3 tires.
            Appearance: Revotec Eagle Eye CCFL Projectors, Red Calibers, 6000k 35w DDM fogs, 6000k 55w DDM lows, LED Taillights, DDM Tuning LED Switchback Turn Signals, Konig Crown 17x7.5 Rims. 30% tint in front windows, rear windows @ 15% tint
            Safety & Security: Cobra XRS 9470 Radar Detector, Experimental 2mm rear mounted camera with Bluetooth connectivity to my phone, GOSHERS Universal Blind Spot Detection System w/ LED Indicators, Waze GPS App with a windshield mount for early warning for police coupled with Radar Detector (double-whammy).
            Experimental: BG 44k, BG MOA, BG ATC, Custom Transmission Cooler, Super Secret Flux-capacitor transporter, Header reflective wrap, CAI 2000 degree radiant reflective wrap.
            Progression: http://www.g6performance.com/forum/s...ad.php?t=22823
            • #81
              [QUOTE=Deathmage;537239].... if I don't answer does this give you your answer?
              haha maybe
              • #82
                Hey we all gotta start somewhere right?
                Trans coolers are primarily for automatic transmissions (tap shift doesn't matter) since the fluid in an auto trans does a lot more than just lubricate everything its always being pumped around so cooling it helps tremendously.
                Manual transmissions just use gear oil, and it isn't pumped around so there isn't a way to install a cooler. Just an fyi
                But tap shit or no tap shift it should improve your transmission as well!
                • #83
                  • #84
                    it was bunnin chevrolet. they are just scared I'll blame them for a leak, but now that I know what I am doing and have full understanding of this an fitting methot, I'm gonna get a flush buy the parts and install it all myself. after seeing the vids you showed me it looks incredibly easy to do.
                    • #85
                      Looks like i found this weekends project lol
                      • #86
                        Yea it is pretty simple for a solid connection. I want to do it as well I just need the money for everything... and the time ha
                        Haha right! You'll be pretty happy with the results.
