Re: Adding Paddleshifters
i guess i forgot about this thread, but i sucessfully did this almost a year ago and all that is needed is to add ONE WIRE...however those that cant solder/ improvise will need a new stering wheel clock spring coil..... the stock one on those that didnt come with paddle shifters has 2 EXRTRA pins un used, BUT they are cut off short so that even if you get extra terminals to install into the stock connector they wont reach the contacts......
and you do need the whole wheel as the older models dont have the cutouts or mounting points for the paddles the only thing not yet workin are the info and enter buttons and im not sure if its a wireing or programming problem, as i also have the 09.5 cluster installed and working minus the stering wheel controls for the DIC
also beware the malibu wheels with paddle shifters arent alway leathwer wheels as i found out the hard way, and the buttons light up green rather than red
