Current Modifications: 18' Sky Wheels w/ 245/40-18 Tires, 25mm Spacers, Megan Racing Coilovers, Racingline STB, JPE Rear Camber Kit, Energy Suspension Poly Bushings, Painted Calipers, Double Drilled/Slotted Rotors, Ceramic Brake Pads, Street Series MMI, CRABS with FPU, NGK Iridium Plugs, Kingsborne 8mm Wires, Custom Magnaflow Exhaust, Custom 2ga Grounding Kit, DDM 6k HIDs High/Low/Fog, Halos, High/Fog Mod, Chrome Recessed Upper and Lower Grills, GM Ground Effects Kit, GXP Rear Bumper, GXP Sedan Hammerhead, 15% Tint, Custom Painted Engine Cover, Painted Mirror Caps, Tinted Tails, QuickLifts, PAC Audio Input, Interior LED Conversion, Dash LED Accents, 3W LED Trunk Lighting
Re: EXHAUST!(Any Info or questions post here)
Originally posted by 91atrac View PostIs that Straight pipe to that muffler only? That crackling bothers me. So far the cherry bomb glass packs setup is the only thing that's made me happy haha2009 Ford Mustang Premium Pony 4.0L
2001 GMC Sierra SL 4.3L
Originally posted by lueshe View PostI installed my CRAB intake a few weeks ago, and finally installed the new exhaust on Friday. I went with:
2.5" to 4" tips.
It has a nice low rumble to it until I step on it. Overall, I'd say i'm satisfied. I need to take pictures and put a video together.
this is the best sound ive heard while looking through exhaust clips, i know you said you dont know much about the 3.5 but do you know if anyone has used a similar setup as yours on a 3.5 already,,, i cant find one there are sooo many clips and exhaust posts lol
Magnaflow makes a single exit set up
Originally posted by ahuhnso i just realized there a drawer in my room that has nothing in it but tequila, condoms and a blow up doll. cant figure out if thats a good thing or not
Originally posted by 91atrac View PostHas anyone done a single exhaust instead of the dual? I'm thinking of doing double muffler single 2.5" cat back with 24" resonator and a muffler I'll have to look into.Mods: BMD Adjustable Front End Links, BMD Stainless Steel Brake Lines, Koni Yellow Sport Dampers, Pedders Lowering Springs, Brembo Upgrade, Racingline STB, Custom Intake, 8000k Lowbeam HIDs, 10000k Foglight HIDs, Badge & Doorsill Overlays, GM G6 Logo Mats, Blacked Out Window Trim, Blacked Out Grills, Pioneer Headunit, 2 10" Kenwood Subs
My Progression
BMD Performance products
Saw your photos. I think I'm gonna do fully custom: cut the stock resonator out and put 24" glasspacks cherry bomb resonator, a single in and out muffler... Not sure what one yet and a single or dual Apexi n1 muffler. Yea it's an import muffler but I have it and it sounds great on the LS motors so should be fine.
Priced out new exhaust yesterday and have a concern. Saw a lot of people on the board ran a single 2 1/2" pipe from the "Y" back. I wanted to do this but the 3.9 on my 'vert currently has 1 3/4" factory piping. Is this too much of a stepup? Am I going to loose all my torque off the line? As we know the 'vert is the heaviest of the 6's and needs the torque to get moving.
Originally posted by Rannin Ravensight View PostOpen it up. The convertible is a pig, and it's not helped by the factory literally crushing the exhaust pipes to clear the chassis bracing.
I am planning on using Magnaflow. Should I use a single in dual out or "Y" it after the gas tank and run twin muffs?
I have a part # of 12226 on the single in dual out.
Kmans car on G6OC has a twim muff system on it. Got me wonndering how much would it add/ Take away to run a single vs twins.
AFAIK, muffler choice and number of mufflers only affects sound. I mean, I guess there are minute power band changes between all the different types and brands, but I don't think you should be able to feel a difference between different mufflers on the same size piping.
That being said, Magnaflow seems to be generally preferred in this group.
I don't like magma flow or flowmaster. Both don't sound deep or give the throaty sound engines make.
Hoping to maybe put dual Apexi world sport mufflers on mine. Either straight dual or connected like stock is. No sure yet.
