Eagle Eyes Dual CCFL Halo Projector Headlights
  • Re: Eagle Eyes Dual CCFL Halo Projector Headlights
    Honestly I had this much clearance as well and still needed to drill a hole because the lights are really angled far down, but if your lights are fine and you can see then don't worry about it, but my screw is far out
    I live my life a quarter mile at a time. For those 16 seconds or less... I'm telling my g6... Go faster!!!
    Progression Page
    http://www.g6performance.com/forum/s...t=26265&page=1
      What about the gap between the bumper and headlights? I can see the main wiring connecter through the gap and I'm a little hesitant on washing my car/ getting water behind the headlights.
        If there's that big of a gap, then you likely didn't seat it in your fender correctly.
        Eagle Eyes Projector Headlight Retrofit: http://bit.ly/QKH9rY
        Spyder Auto Projector Headlight Retrofit: http://bit.ly/1iNrmzr
        Like-OEM Reflector Headlight Retrofit: http://bit.ly/1sPAjQi
          So I just recently purchased the black Eagle Eye headlights from saber sport off of eBay, and they are great, except for 1 main thing. The turn signal light on the right headlight won't work. It was lighting up, but wasn't functioning turn-wise. I then thought it might be the bulb, and bought a replacement bulb. That didn't solve the problem. I can only assume that this is something wiring wise then at this point, correct? Is this something that a local place can sort out for me, or do I need to go through the hassle of boxing these back up and sending them back to saber sport? Just wasn't sure what I should do. (I'm sending an email to Saber Sport as well.) Thanks in advance for any advice!
          -- Whatever doesn't kill me, only makes me stronger. --
            Never mind. I contacted Saber Sport and they are shipping me out a replacement headlight assembly, and I will just have to send back the defective one once that arrives. Hopefully this solves the issue.
              Installed my HID fogs the other day and figured I would remove the plastic holed retainer at the tip of the fender that the headlights insert into.
              Fixed the small gap I had under the headlights. They fit perfect now.
                Good job zoom! Sounds you got some quality alone time with your g6. Lol
                  Zoom, your headlights will bounce like crazy without those. You can get the revised retainers using part number 15284612.
                    Yeah, I put large washers under the top two screws to eliminate any bounce. Works great. The washers are huge. Used the biggest that would fit in the headlight mounts. Also with no gap between the headlight and bumper now there is no place for the headlight to move to anyway.
                      Would you mind posting a pic? I'm having a hard time imagining what you did...
                      CRABS WAMS MPD GT-R Brembos and stuff
                        So I am looking into ordering these but I see Sabersport doesn't have them listed anymore but I found these which I believe are the exact same thing.
                        Now, that being said I'm going to ditch my HIDs and go with Opt7 LED headlights in the lows. If they work as well as they say I plan to get them for my highs and even possibly my fogs (I'd be more likely put them in my fogs if I ever remembered to use them) and the silver stealth bulbs.
                        This all being said, are there any suggestions from current owners that they wish they had done when they first got them? I'm guessing I'll have to drill a hole in the frame.
                        20% Tint, Cross-Drilled & Slotted Rotors, Red Painted Calipers, 6000k H.I.D., LED Interior Lights, Carbon Fiber GM Interior, 18" SenDel S26 rims, Volant CAI.
                        Wish List: Homelink, Black Sabersport projector headlights
                          I own a pair, and I did put in evo formance bulbs in the high. I also went with Autovizion 10000k bulbs for lows and 3500k for The frogs. 35watts for lows and fogs. As for what I wish I did to them when I first got them? Hmm....maybe I would had opened them up to reveal them. But I can do this myself. I would change out the ccfls to green halos instead. Since I have a green decal all over my car right now.
                            Any color light other than white, yellow, or off-blue is illegal to have in front of your vehicle.
                              Damn you crushed of dreams! Lol, yeah, it's disappointing. Thanks for the reminder.
                                Unless you don't wanna use your halos out on the road...
