What could be wrong. My front door speakers have no sound coming from them, but the front door tweeters and rear speakers work fine. What could be the issue. I have a factory 6 disk player, but I don't know if its monsoon. Help please.
Front Speakers Not Working
Tags: None
Re: Front Speakers Not Working
soooooo just putting my 2 cents in here if you have a 2.4 then you don't have monsoon unless your g6 was a custom order from factor by it's original owner. that being said, go in your trunk on your right hand side unscrew the molding and peel it back starting from the tail light. if you have monseen your amp will say monsoon on it. assuming the 2.4s have amps at all wiggle the harness that connects to your radio. it should be the last one on the left. the other two are onstar and xm radio. anyways if you wiggle it and play with the harness and your sound still doesnt come back on then you need to see a dealer or stereo shop LOL
i might post picks of mine...i have a problem where my harness is not acting right anymore and is defective
how do you replace these speakers? - this is probably a retarded question, but is there a How-to? - I'd like to replace my two front door speakers with something a bit higher in quality, I think they are getting a little worn out. (a bit crackly at the high settings now after 3 years)Performance: WAMS, K&N 69 Series CAI, Custom Magnaflow Exhaust built with a Camaro SS Muffler and Glasspack with 4 inch double-wall stainless steel tips, Thunderbolt 8.2mm High-Performance Spark Plug Wires, NGK Laser Iridium Spark Plugs, Pennzoil Ultra Full Synthetic, Resonator Delete, Racingline Motor Mount Inserts, Racingline Grounding kit. (4 additional grounds from battery to front bumper for DDM tuning HIDS)
Handling: Moog Front Control Arms and Toe Ends, Racingline STB, Koni Yellow "4 Point" Suspension -Front to Rear- , Energy Suspension Poly Front Sway Bar bushings, Energy Suspension Tie-rod bushings, Energy Suspension Front Control Arm replacement mounts, Eibach Pro-kit springs, BMD Front Endlinks, Genuine Saab .9mm Rear Chamber Shims, 19mm Motorsports spacers on all 4 tires.
Stopping: Cobalt SS Front Brembo's, R1Concepts Premium Cross-slotted Front Rotors, R1Concepts Premium Cross-slotted and Drilled rear Rotors, Hawk HPS pads, ATE Super Blue Brake Fluid, BMD Steel Braided Brake Lines, Michelin Pilot Sport A/S 3 tires.
Appearance: Revotec Eagle Eye CCFL Projectors, Red Calibers, 6000k 35w DDM fogs, 6000k 55w DDM lows, LED Taillights, DDM Tuning LED Switchback Turn Signals, Konig Crown 17x7.5 Rims. 30% tint in front windows, rear windows @ 15% tint
Safety & Security: Cobra XRS 9470 Radar Detector, Experimental 2mm rear mounted camera with Bluetooth connectivity to my phone, GOSHERS Universal Blind Spot Detection System w/ LED Indicators, Waze GPS App with a windshield mount for early warning for police coupled with Radar Detector (double-whammy).
Experimental: BG 44k, BG MOA, BG ATC, Custom Transmission Cooler, Super Secret Flux-capacitor transporter, Header reflective wrap, CAI 2000 degree radiant reflective wrap.
Progression: http://www.g6performance.com/forum/s...ad.php?t=22823
It's pretty simple. You remove the door panels, undo the screw above the speaker, remove the speaker and disconnect the wires. I believe you can get mounting adapters and wire adapters from crutchfield or wherever, so if you get them, them to install the new ones you just screw the speakers into the adapters, solder the wire adapters to the speakers, plug in the wiring, mount the speaker and reinstall the door panel. If you are doing component speakers, the the wiring adapter would get soldered to the crossover, you'd have to run wiring to the woofer and the tweeter (which would be mounted in the sail panel). Components aren't much more complicated.
Originally posted by Dmanj View PostIt's pretty simple. You remove the door panels, undo the screw above the speaker, remove the speaker and disconnect the wires. I believe you can get mounting adapters and wire adapters from crutchfield or wherever, so if you get them, them to install the new ones you just screw the speakers into the adapters, solder the wire adapters to the speakers, plug in the wiring, mount the speaker and reinstall the door panel. If you are doing component speakers, the the wiring adapter would get soldered to the crossover, you'd have to run wiring to the woofer and the tweeter (which would be mounted in the sail panel). Components aren't much more complicated.Performance: WAMS, K&N 69 Series CAI, Custom Magnaflow Exhaust built with a Camaro SS Muffler and Glasspack with 4 inch double-wall stainless steel tips, Thunderbolt 8.2mm High-Performance Spark Plug Wires, NGK Laser Iridium Spark Plugs, Pennzoil Ultra Full Synthetic, Resonator Delete, Racingline Motor Mount Inserts, Racingline Grounding kit. (4 additional grounds from battery to front bumper for DDM tuning HIDS)
Originally posted by Dmanj View PostAs long as the depth of them isn't too deep they will fit.Performance: WAMS, K&N 69 Series CAI, Custom Magnaflow Exhaust built with a Camaro SS Muffler and Glasspack with 4 inch double-wall stainless steel tips, Thunderbolt 8.2mm High-Performance Spark Plug Wires, NGK Laser Iridium Spark Plugs, Pennzoil Ultra Full Synthetic, Resonator Delete, Racingline Motor Mount Inserts, Racingline Grounding kit. (4 additional grounds from battery to front bumper for DDM tuning HIDS)
If you get these they would be plug n play. However, do you have the monsoon system? If you do I dont think those will work. And if you get those speakers, the sound output will be cut in half since the stock speakers are 2ohm and those aftermarket ones are 4 ohm.
Originally posted by Dmanj View PostIf you get these they would be plug n play. However, do you have the monsoon system? If you do I dont think those will work. And if you get those speakers, the sound output will be cut in half since the stock speakers are 2ohm and those aftermarket ones are 4 ohm.Performance: WAMS, K&N 69 Series CAI, Custom Magnaflow Exhaust built with a Camaro SS Muffler and Glasspack with 4 inch double-wall stainless steel tips, Thunderbolt 8.2mm High-Performance Spark Plug Wires, NGK Laser Iridium Spark Plugs, Pennzoil Ultra Full Synthetic, Resonator Delete, Racingline Motor Mount Inserts, Racingline Grounding kit. (4 additional grounds from battery to front bumper for DDM tuning HIDS)
Any aftermarket speakers are better than oem. You probably don't want to hear this, but imo, either replace them with oem speakers, or rip the entire stereo out and go aftermarket. IMO the monsoon system is not worth the hassle.
Originally posted by Dmanj View PostAny aftermarket speakers are better than oem. You probably don't want to hear this, but imo, either replace them with oem speakers, or rip the entire stereo out and go aftermarket. IMO the monsoon system is not worth the hassle.
Any recommendations?Performance: WAMS, K&N 69 Series CAI, Custom Magnaflow Exhaust built with a Camaro SS Muffler and Glasspack with 4 inch double-wall stainless steel tips, Thunderbolt 8.2mm High-Performance Spark Plug Wires, NGK Laser Iridium Spark Plugs, Pennzoil Ultra Full Synthetic, Resonator Delete, Racingline Motor Mount Inserts, Racingline Grounding kit. (4 additional grounds from battery to front bumper for DDM tuning HIDS)
Mine did this last year. I had a ground wire that almost completely wiggled its way out. It was in the trunk to the left peel back the carpet that's where my loose ground was.Mods:Wams lx9 tune, gtp rear valance, custom Flowtech catback, volant cai and box, raceline stb, CM lowering springs, pioneer touch screen stereo, black vinyle arrow head overlays, Pontiac rear window decal and finally g6performance decals.
Not much left without dumping a few grand so I guess ill be redoing the stock sound system with polk audio everything.
Originally posted by slpg6 View PostMine did this last year. I had a ground wire that almost completely wiggled its way out. It was in the trunk to the left peel back the carpet that's where my loose ground was.Performance: WAMS, K&N 69 Series CAI, Custom Magnaflow Exhaust built with a Camaro SS Muffler and Glasspack with 4 inch double-wall stainless steel tips, Thunderbolt 8.2mm High-Performance Spark Plug Wires, NGK Laser Iridium Spark Plugs, Pennzoil Ultra Full Synthetic, Resonator Delete, Racingline Motor Mount Inserts, Racingline Grounding kit. (4 additional grounds from battery to front bumper for DDM tuning HIDS)
