Wisdom's G6
  • Wisdom's G6
    Wisdom's 06 G6 3.5
    As purchased
    Prepped mirror covers
    Painted Mirror covers
    Blacked out Door Trim
    Blacked out Darts
    Blacked out badges
    Body matched engine cover ( I can't stand GM black plastic)
    A little Preventative maintenance never hurt.
    Prepping my grill surrounds for paint
    Sand, Primmer, Wet Sand Primmer, Wet Sand, Color, Wet Sand, Color, Wet Sand, Color, Clear coat, Clear coat.
    Installed
    I ripped out that crappy plastic air box and mocked up a heat shield.
    I managed to track down the parts needed to put together a half way convincing CAI.
    Once I was happy with the fit. I used the Bud Light template to fab up the real deal.
    It's been on the car for almost a year I think with no problems. After looking at it I can see that I should have had one more bend in there.
    I got sick of peaking around the steering wheel to spot the fog light switch so I flipped the assembly over.
    most recently was the installation of courtesy/puddle lights, witch I am very happy with.
    http://www.g6performance.com/forum/s...ad.php?t=22777
    CIA Mock up and installation with pics
    http://www.g6performance.com/forum/s...ad.php?t=20762
    Steering wheel swap with pics
    http://www.g6performance.com/forum/s...740#post508740
    New Bumper Installation with pics
    Stop by my progression and say Hi!
    Custom Blacked out Chrome
    Color Matched Upper Grilles
    Door Sills
    Puddle Lights
    Steering Wheel swap
    Custom CIA/Heat Shield
    Re: Wisdom's g6
    Right on dude. I like your take on the heat shield. But you should have went with a Newcastle heat shield.
    Custom Flowmaster Exhaust- CRAB Heat Shield- Tiger Ram- Painted Cals- Painted Grills- Eibach ProKit- Racingline S/B- Racingline G/K- Injen Air Intake- Spyder Headlights w/ DDM 5000k Lows- DDM 5000k Fogs- Plasti-Dip Solstice Wheels w/ 5mm Spacers/ Painted- Painted Intake Manifold- Hood Spacers- RotorPros Front/ Rear D/S Rotors- BMD-P Fr. Endlinks- BMD-P SS Brake Lines...
    Progression:
    http://www.g6performance.com/forum/s...ad.php?t=18485
      Re: Wisdom's g6
      well thanks man. During fab I actually anticipated having to do this a few times to get it right. This was my first attempt, I may still redo it. I would like to buy the Crabs Front pipe to finish it off. Or, try to make something out of off the shelf parts. If make something, I for see mounting being the biggest issue.
      Door Sills
      Puddle Lights
      Steering Wheel swap
        Re: Wisdom's g6
        I love the body colored mirror covers! Where did you get the mirror covers or did you fab them also?
          Re: Wisdom's g6
          Nope. They are already on the mirrors you just pop them off. I sanded mine smooth because they have that black plastic texture to the.
          Door Sills
          Puddle Lights
          Steering Wheel swap
            Re: Wisdom's g6
            Nice dude. How did you get the covers off? just a flat head?
              Re: Wisdom's g6
              Mirror cover how to...
              http://www.g6performance.com/forum/s...=mirror+covers
              I was able to use this as a guide to find the clips. then I just moved the mirror glass around so I could get to them without popping the glass off. I think I used a flat head and a flashlight.
              Door Sills
              Puddle Lights
              Steering Wheel swap
                Re: Wisdom's g6
                edited for updates! Sheggit' Out!
                Door Sills
                Puddle Lights
                Steering Wheel swap
                  Re: Wisdom's g6
                  New Door Sill Plates GM:12499448
                  Got Em for 20.00
                  Sheggit out.
                  Door Sills
                  Puddle Lights
                  Steering Wheel swap
                    Re: Wisdom's g6
                    New bumper. Relieved to be looking sweet again!
                    http://www.g6performance.com/forum/s...ad.php?t=22837
                    Door Sills
                    Puddle Lights
                    Steering Wheel swap
                      Re: Wisdom's g6
                      Coming along nicely sir. May I recommend updating the rims? I switch mine to the gtp rims but in your case I think some spacers an solstice wheels would make it look sweet.
                      MY PROGRESSION:
                      http://www.g6performance.com/forum/showthread.php?t=20385
                      Mods: Classic Performance Exhaust, WAMS 93 Octane tune, Crab Intake, and a whole lot more...
                        Re: Wisdom's g6
                        Man, I am totally with you. It's on my list. I'm going to get the life out of these tires and save up for some rims. I love the look of the Solstice five spoke brushed aluminum wheels. I just gotta find a good deal on them. Honestly I would be happy with anything over the stock 16 in.
                        Door Sills
                        Puddle Lights
                        Steering Wheel swap
                          Re: Wisdom's g6
                          Oh... I just checked your progression, and you have the rims I'm talking about. are those the G6 or Solstice rims. Or are they the same? your car looks awesome.
                          Thanks
                          Door Sills
                          Puddle Lights
                          Steering Wheel swap
                            Re: Wisdom's g6
                            Finally got a good picture of my entry lights. They are wired into the dome light circuitry so they come on when I push the lock or unlock on the key fob. They also come on when you open the door and go off when you put the car in gear.
                            I'm thinking of cutting the LED strip in half and extending half of it to the rear doors.
                            Door Sills
                            Puddle Lights
                            Steering Wheel swap
                              Re: Wisdom's g6
                              Looking good. Granite metallic looks best on our cars.
                              Traded G6 - http://www.g6performance.com/forum/s...ad.php?t=17590
                              2006 G6 V6, 12" vinyl strip along windshield, 5% tint on all around, painted mirrors, Eibach Pro-Kit, CRABS Option 3, Dr. Speed FPU, 8k Highs/Lows with halogen fogs, tinted tails, custom Flowmaster 44 exhaust with resonator delete, and a Kenwood headunit along with a metra kit.
                              New Car - http://www.g6performance.com/forum/s...ad.php?t=22863
                              2009 Cobalt SS/TC, K&N SRI, ZZP catless DP, EFR 6758, Polished TC wheels, Injen Charge pipes, Retros, HPTuned, etc...
