Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 72
Thread: Install Koni Yellow Sport Dampers
  1. #31
    VMware Solutions Engineer Photobucket
    suckit
    Photobucket
    Established G6er
    Deathmage's Avatar
    Oct 2011
    Poughkeepsie, NY
    1,158
    Name
    Trevor
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    4 Speed Auto with Tapshift
    Style
    Sedan
    Color
    Black
    Re: Install Koni Yellow Sport Dampers
    Quote Originally Posted by theshibbykumquat View Post
    Glad to see you went through with this and that you're enjoying them! I wouldn't really say it makes the car feel any less stiff, just helps to keep the ride smooth and in control with stiffer springs... This really just started out for me as an experiment trying to see if it would work, but it came out great and really makes a huge difference.
    it's a perfect combination with the Eibach springs, you have Peddlers so I'm sure yours is a bit different. The Eibach's are even lower and for me personally the ride is amazing.
    Bumps still feel like bumps but as you know what I mean Bryant the bumps are less harsh. The best way to describe them is those spots in highway were you get that "zero gravity" feeling is what it feels like when going over bumps; it's just really smooth.
    Lane-to-lane transfer of weight at speed or any speed is precise and smooth; lane shifting is the only time I can feel the Eibach's working all the other times the Koni's really do all the work.
    When on cruise and touring the comfort levels on highways is like luxury car smooth....
    High speed cornering is also amazing; last night as stated above when I was in-tow on the A6 I had a turn on the NJ Garden State Parkway where there was such a hard bank that before with the Monroe's in the front the control would be hard. Well lets just say I was doing in excess of 95+ around a corner and the car was so freaking smooth and precise it was utterly amazing. My Cobra detected radar uphead and my Waze app reported a radar trap 3/4 mile ahead and I slammed on the brakes gracefully to 75 and cruised on by them with the traffic flow but still I was in utter amazement as to the agility and precision the car has now....
  2. #32
    suckit
    Photobucket
    Established G6er
    Deathmage's Avatar
    Oct 2011
    Poughkeepsie, NY
    1,158
    Name
    Trevor
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    Style
    Sedan
    Color
    Black
    Bryant,
    Have you fine tuned your suspension yet? I'm having a hard time to find my sweet spot. one complete turn past full soft is way to stiff. If I do half a turn past full soft it's like too loose. lol just trying to find the sweet spot. I'm also riding with 27psi in the front and 31psi in the rear (cold) so add on like 4 psi on the highway. I'm wondering if i bumped the fronts to say 33psi cold if that would make a difference.
    Basically as I'm sure you know what I mean, moving that adjustment in the front even 1 cm soft/firm makes a huge difference. Basically this is what I'm looking for. I like the stiffness of the rear at one full turn past full soft since it controls the ass way better, but I like a soft controlled front end but with a responsive touch. I'm going to use a scale of 1 to 10 (1 being full soft, 10 being one full turn past full soft); I'm basically tossed between 4 and 7. 3 is just way to soft and when I turn the steering wheel I really got to turn it to get a responce but then it feels loose and it feels like the piston has less resistance as it should since duh it's softer. If I go to like 8 it really responds but feels like I'm steering a 4000lb tank but it really just the stiff resistance.
    I'm going to see if setting it to 4.5 is better and bumping the psi in the front to say 33; it's currently at 27 in the colder mornings until it gets to 31 highway in the front and 35 in the rear (which the rear feels fine right now). it's just my front that feels weird; I think these really cold morning aren't agreeing with the shocks very well. They take a while to "warm up".
    Also on a side note, when you reset yours do you reset yours back to full soft and then go to your firmer setting or do you notch forward/backwards from your current position? - I'm curious if I'm doing it correctly
    lol I'm going to be playing with these things forever I think. -- just curious if you've had this fun issue too!!!!
  3. #33
    suckit
    Active G6er
    theshibbykumquat's Avatar
    Aug 2011
    Central NJ
    724
    Name
    Bryant
    Year
    2006
    Make
    Pontiac
    Model
    G6
    Trim
    V6
    Engine
    3.5L V6 LX9
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Stealth Gray Metallic
    Quote Originally Posted by Deathmage View Post
    Bryant,
    Mine are pretty good right now, I have 1 1/4 turns in the front and 1 full in the rear, but my spring rates are likely different then yours so don't expect it to be the same.
    To answer the other question, every time I adjust I do bottom it at full soft first and then adjust upward from there. If you're just adjusting back and forth from the current position that could be part of the reason you're having a hard time dialing it in. The adjustments have some lash in them, so if you're not starting at the same point every time (full soft) then its hard to tell exactly where its adjusted to.
    Also check your tire pressures, front should be 30 at minimum. And as a rule of thumb for our cars you would almost always want the front tire pressures higher than the rears, or the front end may start to wash it.
    My Progression
    BMD Performance products
  4. #34
    suckit
    Photobucket
    Established G6er
    Deathmage's Avatar
    Oct 2011
    Poughkeepsie, NY
    1,158
    Name
    Trevor
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    Style
    Sedan
    Color
    Black
    I've determined there is nothing wrong with the Koni's it's just the winter temps plus the salt and the potholes that seem to reproduce like crazy that is the core problem.....
    on Interstates, IE the one that was paved over the summer is so smooth it's crazy. it's so smooth to the point last night (@ 3 am coming home from work) I realized I was doing 96 mph and didn't even feel the road.
  5. #35
    suckit
    G6 Newbie
    Jan 2014
    Michigan
    10
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.4L V6 LNJ
    Transmission
    4 Speed Auto
    Style
    Coupe
    Color
    Sport Red Metallic
    Very nice thread.
    I was wondering if someone could post the part numbers for the Koni's. The two links to the tire rack have two different part numbers for both the front and the rears. I just want to make sure I get the right parts the first time.
  6. #36
    suckit
    Photobucket
    Established G6er
    Deathmage's Avatar
    Oct 2011
    Poughkeepsie, NY
    1,158
    Name
    Trevor
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    Style
    Sedan
    Color
    Black
    Quote Originally Posted by AMFAB View Post
    Very nice thread.
    It's a custom job all the way around. the part number won't match our car on website but the parts do match up to our car.
    The rears are a simple bolt on and shop can do them. The front's are inserts meant for a Cobalt SS but they work perfectly fine for us... you will need an old set of shocks from a junkyard from a Malibu, Cobalt, Aura, or G6 from years 2005 to 2008 in order to do this project. Also they will need to be a left and right shock.
  7. #37
    suckit
    G6 Newbie
    Jan 2014
    Michigan
    10
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.4L V6 LNJ
    Transmission
    4 Speed Auto
    Style
    Coupe
    Color
    Sport Red Metallic
    So basically I will need to get the adjustables and get some strut housings from a Malibu, Cobalt, Aura, or G6 from years 2005 to 2008 and use part number Koni Manufacturer Part #: 8641-1500SPORT for the fronts and part number Manufacturer Part #: 8741-1479LSPORT for the left and part number Manufacturer Part #: 8741-1479RSPORT for the right.
    Is there a reason not to use my original strut housing's? nWell besides the fact that there the originals and I may want to re-use them ?
  8. #38
    Photobucket
    suckit
    Medium-Rare G6er
    Sep 2013
    New York
    180
    Year
    2007
    Make
    Pontiac
    Model
    G6
    Trim
    GTP
    Engine
    3.6L V6 LY7
    Transmission
    6 Speed Auto with Tapshift
    Style
    Coupe
    Color
    Black
    For the rears use: 8040-1342Sport
    As for the front strut housing and why to use an extra set: You can have the strut cut, painted, install the insert, and get it ready before even jacking up the car. Lets say you take it apart, and your car is sitting with no front end and you NEED to drive somewhere.... good luck.
    Lets say you mess up the cut, or something along those lines, and now you need to order an extra set, you are now going to end up waiting at least 3 days, probably longer. With no car.....
    Mods: Racingline STB, Racingline grounding kit, Racingline MMI, Crabs Intake O3 w/ FPU, Redline Quicklift PLUS, Front R1Concepts Drilled and Slotted Rotors, Posi Quiet Ceramic Pads, BMD Adjustable Endlinks, H&R Sport Lowering springs, WAMS 93 Octane ECM Tune
    Appearance Mods: Eagle Eye Projector Headlights (Black), Dart Carbon Fiber Overlays, Full Debadge, Plastidipped Grill, Black Altezza Tail Lights, Red Interior LEDs
  9. #39
    suckit
    Photobucket
    Established G6er
    Deathmage's Avatar
    Oct 2011
    Poughkeepsie, NY
    1,158
    Name
    Trevor
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    Style
    Sedan
    Color
    Black
    Quote Originally Posted by ckeelan2087 View Post
    Exactly. use the mush between those ears; I know it may be painful to think.
  10. #40
    suckit
    suckit
    Active G6er
    Altered6's Avatar
    Nov 2010
    720
    Year
    2007
    Make
    Pontiac
    Model
    G6
    Trim
    V6
    Engine
    3.5Lvvt V6 LZ4
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Crimson Red
    Just a heads-up that Tire Rack currently has Koni's 25% off until May 31, 2014.
    245/45/17 Bridgestone Potenza RE-01 R, 245/45/17 Bridgestone Blizzak WS60, Eibach springs, Debadged, Recessed upper grills, GTP rear valance, GXP exhaust, Redline Tuning QuickLifts, K&N air filter, GMPP strut tower brace, Steering wheel stereo controls, Baer Cobalt 13" front brakes, Cobalt SS 11.75" rear brakes, Stainless steel braided brake lines front & rear, Leather steering wheel, Recessed lower grills, Leather shifter handle, Leather parking brake handle, Leather console lid cover, Volant intake, PIAA H9 & H11 Xtreme White Plus headlights & driving lights, 93 octane tuned ECM & TCM, Custom painted headlights, Motorsport Tech wheel adapters, C5 Corvette 17" x 8.5" wheels, Koni Sport struts and shocks, MSD 8.5mm Super Conductor plug wires, Racingline polyurethane motor mount inserts...
    Altered6 Progression Page
  11. #41
    suckit
    Photobucket
    Established G6er
    Deathmage's Avatar
    Oct 2011
    Poughkeepsie, NY
    1,158
    Name
    Trevor
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    Style
    Sedan
    Color
    Black
    Quote Originally Posted by Altered6 View Post
    you guys better pounce on that!
  12. #42
    suckit
    Active G6er
    Aug 2011
    Central NJ
    724
    Name
    Bryant
    Year
    2006
    Make
    Pontiac
    Model
    G6
    Trim
    V6
    Engine
    3.5L V6 LX9
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Awesome deal! I bought all mine from Tire Rack last year when they had the same sale!
    My Progression
  13. #43
    Photobucket
    Photobucket
    Photobucket
    suckit
    Medium-Rare G6er
    RedMoon Roku's Avatar
    Jan 2011
    Evansville, Indiana
    251
    Name
    Darius Neighbors
    Year
    2006
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    Style
    Coupe
    Color
    Sport Red Metallic
    XBox LIVE Gamercard
    Darikun PontiG6
    Thread Revival - This is a good how to thread. I just installed the rear dampers today and I'm planning to start on the front struts sometime before the weekend. I just need to find a pair of used struts housings for extra insurance in case I mess up the cuts for the inserts.
    Roku's Mods: K&N air intake system, Eibach lowering springs, 225/45R18 Bridgestone Potenza RE970AS Pole Postion Tires, 18in OZ Ultraleggera wheels (black), Disc Italia brake pads and slotted rotors, debadged, 30% window tint, Eagle Eye headlights (black), DDM 6000K HID low headlights, Notto SE 10000K HID fog lights, LED taillights, Koni shock absorbers and front struts, Racingline strut tower bar and grounding kit, Sirius Satellite Radio, BMD front end links, BMD steel braided brake lines, Brembo four piston front brake calipers, MPD ram air hood (body color), upper and lower recessed grilles (body color) GM Ground Effects kit (body color), Hammerhead flushmount spolier (body color), Customized Pontiac Concept Dart (Black w/ Carbon Fiber), Remin carbon fiber dash kit, WAMS ECM 91 Octane Tune, Borla pro xs dual muffler exhaust with vibrant resonator
    Roku's progression:http://www.g6performance.com/forum/s...36&pagenumber=
  14. #44
    suckit
    G6 Newbie
    Jan 2014
    Michigan
    10
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.4L V6 LNJ
    Transmission
    4 Speed Auto
    Style
    Coupe
    Color
    Sport Red Metallic
    I have a good set of used ones off from my 2008 GT, I don't know how far away you are from me but I'm sure we could work something out if you really wanted them?
  15. #45
    Photobucket
    Photobucket
    Photobucket
    suckit
    Medium-Rare G6er
    Jan 2011
    Evansville, Indiana
    251
    Name
    Darius Neighbors
    Year
    2006
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    Style
    Coupe
    Color
    Sport Red Metallic
    XBox LIVE Gamercard
    Darikun PontiG6
    I'm in the southwest part of Indy. I can find some, no problem. Thanks though.
