EBC Ultimax Sport Rotors - USR Style & Duralast Gold Brake Pads
  • EBC Ultimax Sport Rotors - USR Style & Duralast Gold Brake Pads
    Brand: EBC / Duralast
    Price: 192$ W/ Shipping / 35$
    Purchased From: Ebay / Autozone
    Installation: (Use easy, moderate, involved, or difficult) Easiest install I've done yet
    Installation Time: 1 and 1/2 Hours
    Any Installation Tips You Have: Read this walk through http://www.g6ownersclub.com/forum/showthread.php?t=8023. Also, the inner brake pad is a beyotch to slide in the housing, and that's natural.
    Quality of Part: (rate 1-10) 10 (So far, will update)
    Product Performance: (rate 1-10) 10
    Would you Recommend to Others: Most definitely. The EBC Rotors seem to be really high quality, but I truly can't comment until 2,000 miles later or so.
    Any Other Comments:
    The braking quality is unbelievable with these ceramic pad and slotted rotor combo. Some jack*** pulled stomped on the brakes in front of me so I had a really good testing opportunity unfortunately.
    Re: EBC Ultimax Sport Rotors - USR Style & Duralast Gold Brake Pads
    So how are these holding up? Did they rust up or are they still looking great?
    20% Tint, Cross-Drilled & Slotted Rotors, Red Painted Calipers, 6000k H.I.D., LED Interior Lights, Carbon Fiber GM Interior, 18" SenDel S26 rims, Volant CAI.
    Wish List: Homelink, Black Sabersport projector headlights
      I have the exact ones, and they are holding up just fine
        Warped after a year. I'm just going to buy sets off of eBay every time I need a set. I quickly realized this cars braking set-up is doomed to failure.
          I have been using the same R1 e-line rotors since 09 and I don't have a single bit of warping, only reason I want to replace mine is due to the rust making them look like garbage with my new rims.
            +1 for R1 e-line
              +1 for R1 e-line
                Can someone snap a photo of their EBC rotors after some usage? I'm probably going to replace mine next summer to get rid of the rusty e-line rotors but I want something that's not going to rust up like these did.
                    Thanks sir! They still look like they have some rust on them =(
                      yah they do, but I abuse these rotors. and my car sits outside all the time.
                        does anyone have any recommendations for rotors that wont rust towards the center area around the hub...I don't need any performance rotors, just ones that won't rust after a month of use
                        "Wheel gap can be compared to a vaginaa. The more fingers you can stick in the worse off you are. "
                          Just pick up some unpainted rotors, then pick up a can of the black hi temp grill paint and spray that hats with it. Its always worked for me
                          My Progression
                          BMD Performance products
                            My new wheels will be here in a couple of days and im about due for some rotors. I'm liking the grill paint idea. Sounds like a pretty goof winner to me as long as it rust resistant. Hardest part will be getting the stupid amount of oil off the rotor so the paint will stick.
                            2008 Pontiac G6 Base "Nothing Out Of The Ordinary"
                            2008 Ford Edge
                            My Progression
                              I would use Gunk Brake Cleaner, that stuff is amazing. I would also check out engine paint or Rust-Oleum high temp paint.
