Ac actuators
  • Ac actuators
    How many actuators does a pontiac g6 has?
    Where is the mode actuator located in a pontiac g6 2006 3.5 L
    Re: Ac actuators
    Maybe someone who has a Chilton or Haynes could answer you. GMmanoff ?
      Re: Ac actuators
      Nice shoutout! I would just like to thank God, GM, Chilton, Mechanics, and DelHuge for this shoutout! If it was not for you all, I would not be here. Thank You!
      Okay, I will see what my Chilton says. I am not familiar with this issue. let me see what I can do.
        Re: Ac actuators
        Would this Mode Actuator have to deal with our coils?
          Re: Ac actuators
          nevermind, I got it now. its for your HVAC system. I am looking up actuators and that mode actuator in the HVAC section
            Re: Ac actuators
            Under the passenger side dash, below the glove box, there is a tray like cover that helps hide the blower motor. you will find that there is an actual separation between the blower motor and where it mounts up at. seems like a deal like you have to pop it out. The Chilton says you have to cut it out by dragging around the motor in a circle. I would try to pry in the gap that you could see. there is a blower motor resistor, a big rectangle piece. check this out too. I was looking at photos on google. I did a search of your year and model with the words blower motor. do that and you will see what I saw.
              Re: Ac actuators
              I am seeing that our cars have one actuator. It is the blend door actuator. it seems like it could be easy to swap out.
                Re: Ac actuators
                Im finding that the HVAC Door actuator is behind the glove box. I hope this helps
                  Re: Ac actuators
                  That's six in-a-row ! Hope he got the answer he was looking for !
                    Re: Ac actuators
                    Actually there are 3 actuators. One on the drivers side of the hvac case, one on the passengers side of the case, and another tucked on the far right on the passenger side behind the glove box I had to replace my upper case so if you have any questions I've got answers!
                      Re: Ac actuators
                      dang! stole my thunder!
                      naw bud, just playing.
                      Im just for anyone to help him out. Im just glad to have helped in which ever way I can. I do it all for Merica
                        Re: Ac actuators
                        Wtf lol XD
                          Re: Ac actuators
                          If you heater doesn't work, a broken blend door could be the problem. Just a FYI expect to pay about $400 or more in parts and at least a week to take everything apart and put it back together. If that ends up being your problem pm me or say on the post, and ill walk you through it.
                            Re: Ac actuators
                            My tempetarue actuator works . My air circulation actutor works. The problem is the mode actutor is bad i know what the prpblem is. The thing is finding the mode actuator. My problem is i only get air from the dash vents. ThanK you all for your help. Last time i check for the actuators. Found 2 on passenger side which are tempetarue and air circulation actutors. I am guess the other 1 is in the driver side.
                              Re: Ac actuators
                              I would never pay 400 bucks it only takes me 24 hours to remove replave the damnn heater lol but thats not the problem. I get cold and hot air
                              But only from dash vents
