I just recently traded my 08 G6 GT in for a 08 G6 GXP. I transferred my GT-R exhaust and my CRAB intake on to the GXP. After a few days my check engine light came on, I ran the diagnostics and pulled these two codes: P0174 a P1175. I check and cleaned the MAF sensor, also checked for leaks throughout my intake system (no leaks). And checked the gas cap as well. I also checked for leaks in my exhaust, I did find a small leak at one of my clamping points (connecting the strait pipe to the u shape pipe) I don’t think that what is causing the cell but I am taking it in to get fully welded. I disconnected my battery terminals for an hour and reinstalled them, turned on the car and no CEL papered. I drove to and from work with no problems. The next time I stared my car I had a CEL with the same codes again, but the CEL went away after 5 Minutes.
Sometimes I have a rough idle and it then will drop to what I think is normal idling operation. And when accelerating it seems sluggish at times but really not that noticeable. When I just had the GT-R installed and the t dealing with stock air box I had no problems. I know the CEL is telling me that my system is running lean; maybe I just got some bad gas
I am going to take it in and use my warranty, I just like to troubleshoot and see if I can make my own repairs first before I start dealing with the dealership.
Anyone else have these problems?
