cig outlet
  • cig outlet
    My cigarette outlet fuse keeps blowing all of a sudden...I put a fuse in and it.just blows..never did this before all of a sudden its doing it...any ideas on what the hell is going on?
    2006 Black GTP Coupe, One of the First Hammerhead Spoilers on here. Gm Strut Bar, Doctor Speed CAB and Stage 4 . Black out upper grille and black logos, Tinted Black Euro's, Painted black Headlights with blacked out corners and Led's,10,000 K HID Low-Beams, GT-R Cat-Back Exhaust System,Racingline performance moto mounts inserts, power slot rotors and hawks.Eclipse 4 channel amp powering Alpine Type-S speakers, 93 oct tune, GM HSRK, RaceineLinePerformance Ground Kit.
    Re: cig outlet
    Short somewhere.
    1972 F100
    1978 Twinstar
    1992 Miata
    2014 Mustang
      Re: cig outlet
      is there any metal or possibly a coin that fell into one of the sockets?
      2009 PONTIAC G8
      MAGNETIC GRAY METALLIC
        Re: cig outlet
        I would have to check
          Re: cig outlet
          Anybody else have ideas what else I can check to figure this problem out?
            Re: cig outlet
            the outlet problebly went bad
            Originally posted by snowmanG6
            you would try to tape a poptart to her then give her a bag a skittles and tell her to fart a rainbow
              Re: cig outlet
              Even though I used it like 5 times since I owned the car?
                Re: cig outlet
                anybody know i can trace this back?
                  Re: cig outlet
                  disconnect the wire harness from the dash mounted outlet and replace the fuse. if it doesn't blow, your problem is there. if it blows, your problem is in the other socket.
                  2009 PONTIAC G8
                    Re: cig outlet
                    Any ideas how to get the one on the dash out?.. can I put a flat head under it and pry it out or will it break that way?
                      Re: cig outlet
                      you will break it.
                      pull off the fuse panel door in the passenger footwell and just unplug it from that side.
                      2009 PONTIAC G8
