Hey guys, new here to G6 performance, I have an 07 G6 base 2.4 auto with 170K on the odometer. Timing shattered at 168K and have since replaced the camshaft and counterbalance shaft timing sets entirely, checked 4x that all timing marks were aligned, have replaced the entire cylinder head, new timing cover, oil pump and water pump, new spark plugs, replaced exhaust cam sensor pigtail, and new camshafts.
Cold start rattles for a few seconds then fades away. Acceleration under load (such as going up hill) engine rattles badly, and then when I pull up to a light or a stop sign the engine misses, stutters, pulls and shakes, causing the whole car to pulse about 3 jerks every second.
OCCASIONALLY we get a check engine light which we can't read because the computer doesn't link to a reader. (Have spent hundreds of hours searching the internet and have seen absolutely ZERO related postings that had been solved, only answer being "dealership could get a code but wouldn't say what it is unless I paid for diagnostics")
Paid 2500 for the car and so far am in 2000 just in parts. Anything helps at this point.
