People have painted them or put chrome door trim on them. See my post in the pictures section called "shot another" for the chrome door trim on the edges.
How To Take Out Upper Grills
The Present: 2010 Mazdaspeed3... Zoom Zoom
The Past: 06 G6 GTP Vert: Westers Tune - GT-R Exhaust - Doc's Stage3 CAI+ CRAB O4+K&N - GMPD Strut - RL Street Inserts - CMS Bespoke Vert Lowering Springs - Quicklifts - Enkei FN18's, N3000's 245/45y18 - 35% Tint Around - 4300k HIDs His & Los - Black Headlight bezels - Black Recessed Grills - Pooners Chrome Trim Blackout - Black Overlays on Darts - Avic f700bt
Yeah, I like the chrome door trim idea - it looks good. I'ld see someone who went the factory chrome grilles.
Well I tried installing my new lower grilles today but had no luck removing the stock ones. I unbolted the lower flap under the bumper so i could work behind but it's still very restrictive to what I can see. There are also 3 round plastic bolts that go into the top of the stock grill and the bumper i'm guessing. What's the best way to remove those? I tried prying something flat in between but they werent budging. I read and tried following the suggestions above but those plastic bolts threw me. There's gotta be a simpler way to remove these things!
are you talking about the plastic connector things? they pull out, might seem to take alot of force because you cant get much behind it from the angle you will be using
if you get the tape all loose you will be able to get them out
Cool, i'll try again tomorrow then.
Re: How To Take Out Upper Grills
Is this the same for the recessed grills as well???Originally posted by bluegtp33Ok fellas and ladies im gonna try to write up a how to on the upper grills. If there is anything else needed or questions just ask and i'll try to answer them
----FACTORY GRILL
----OUTSIDE COVER OF GRILL (CHROME)
To take this off without damaging your car visibly i would advise to put tape on the car if you want and use a new playing card. Also once you get a small flat head in between the cover and the car, pry it toward the chrome(just to clarify: pull handle of screwdriver toward the chrome) not the car, as it will push paint in a smudge(if you pry toward car, if you pry toward chrome shouldnt do any damage).
You will notice by the pictures where the clips should be and i would start with the other edge first, then you can pull a little and it will work itself off the rest of way. If you have problems with this use the flathead to help get rest of clips out, again pry toward chrome!!!!!
----INNER GRILL
Once you have chrome off this is what you will see. You can see the 4 clips for the inner grill. Start with the bottom one, pop it out with flathead screwdriver and it will almost fall the rest of way out. Shouldnt need but to take the one clip out and you can wiggle to get rest if needed.
HERE IS CLIP UP CLOSE, THIS IS THE OUTER CLIP
And that is it.
My progression thread
Car: Black 2007 G6 V6 Sedan
Done: Debadged, 20% tint, Stage 3/4 CRAB Intake, 08 radio w/aux, leather wheel and radio controls, DDM Tuning 6K HID's
In Process (waiting on the install): Black Window Trim, GTP rims, Red painted Calipers
Near Future: Red Angel Eyes, Cquence rotors, color matched headlights, LED tails+3rd brake light
Down the Road: WAMS tune
found the thread... nevermind
when reinstalling the lower grill, do you have to apply more tape or is that just a GM ruin ur project kinda thing? Im now confident about uppers now i just need to get that way about the lowers
so once i cut the retarded ass tape out of the stock ones i can just clip my new ones in?Originally posted by bluegtp33you got the recessed lowers now right?
no tape needed, when you get under the car you will see that it clips on and is only held by these clipssigpic
i chromed my grills with spray paint but i lah a little bit of cracking when the paint dryed. i have been advised how to fix it. but any one else have an input.28% Tint on Rear, 15% on Front, Red interior led's with music interface, Red underglow, Red LED licsense plate bolts, Racing pedals, Custom Windshield decal "G6performanceracing", plus same decals on side rear windows, Special Debadge, MRZ Performance Engine dress up caps, ZZ Performance Strut Tower, Custom Diamond plate Engine Cover, 6000K HIDs lows, Poons Crab Intake, Racingline MMIEibach Springs, Resonator delete
thanks for the tips. im going to have it chrome plated by techni chrome i think.28% Tint on Rear, 15% on Front, Red interior led's with music interface, Red underglow, Red LED licsense plate bolts, Racing pedals, Custom Windshield decal "G6performanceracing", plus same decals on side rear windows, Special Debadge, MRZ Performance Engine dress up caps, ZZ Performance Strut Tower, Custom Diamond plate Engine Cover, 6000K HIDs lows, Poons Crab Intake, Racingline MMIEibach Springs, Resonator delete
