1st remove fuse panel cover, becareful its held on by 2 pacthes of velco. One on the upper right which is held together pretty tight the 2nd piece is on the bottom in the middle. Once those are detached you can slide it out to the right.
Thats the hardest part.
Run your wire how you like since im not interested in ripping apart the dash so i ran it down on the right side of the radio. There is a lip between the center console and dash and with a flathead wrapped in tape you can push in between those for a cleaner look.
You can do the same trick with the flathead and continue down the glove box, make sure you open the glove box. Bring the wire behide the edge of the panel and now you have your wire at the fuse box.
Now you have your ground and power wire.
The ground was simple while looking at the fuse box in the lower left side corner there is a little black bolt you can loose'n it a little bit and put the ground wire between the bolt and washer.
The power was tricky nothing lost power when the car turned off radio, adjustable pedals nothing. I found that the heated seats did and i attached the wire to that fuse and the radar was woking perfect.
dont know what to use if you dont have the heated seats but the fuse should still be there. So thats it hope it helps if anyone else decides to do this.
Sorry for not taking pics.
