Turbo/ Super Charger info.
  • #46
    Re: Turbo/ Super Charger info.
    I need a programmer. Has anyone tried the Superchips 2825. Anyone have any thoughts? I don't want to send out my ECU if I don't have to. As for the turbo, I would think it would match right up. I mean being the same engine and all. I have another question. Let's say I add a Hahn turbo kit, Magnaflow 2.5" exhaust, Magnaflow 2.25" O2 catalytic converter, and a Zex 4 cyl. direct port nitrous kit at 75 hp. Assuming everything fits correctly and is installed perfectly and has a proper tuning, would the stock engine be able to handle all that? Or do you think that the stock parts would blow apart/get damaged?
    EDIT
    What about the HP Tuners programer. Will that work with the 2.4L G6 to program it with a turbo, exhaust, and nos?
    • #47
      like I said I'm not that familier with that engine but assuming that they are the same as the cobalt you shouldn't had a problem as LNG as u lower the compresion a but like mentioned before and a few other things and it should be fine. Even though thy a re the sane wngibs the turbo might not be exact fit as far as routing abd such cuz they are two different engine. Bays. As far as tuning is concerned I would go with hp tuners just look to see if it is supported I don't see why not
      750WHP Magnacharged GTO.....WTF!
      TVS2300 GTO, Innovators West 8" Overdrive Pulley, ECS Tensioner, SD tuned by Andrew at Complete street performance, Ed Curtis custom Lunati camshaft 230/236 .6XX/.6XX 113 LSA, Hardened Pushrods, Lunati .675 lift Valve Springs, Single Walbro 255 fuel pump in stock bucket, Kooks 1 7/8 Jet hot coated Headers , Kooks 3" catless mid pipes with DMH low pro electric cutouts, Spintech 2.5" stainless steel exhaust with X pipe, Carbon fiber Cold air box with AEM air filter, Billet products short shifter, JamesBiz Oil catch can, Pedders 5/16" raise springs with drag bags, Weld RTS Black with Hoosiers
      Show
      -20% tint
      -bohaman AUX-in radio mod
      -Professionally heated seats
      • #48
        ok. thanks for the help. i'll just have to make my own custom piping/tubing if it don't fit. I will lower the compression. the engine should be able to handle all that with a lower compression. the car is supported by hp. i'll have to see if it works with turbo and nos tunes (different tunes-street and nos). i'm going to see if my local shop will take care of it all. esspecially the tune. thanks for your help.
        • #49
          No problem! glad I could help
          Show
          -20% tint
          • #50
            I have one last question. Is nitrous bad for the engine? Does it really eat and ruin the engine? Even if correctly installed? I hear a lot of people saying that nitrous will eat away at the engine. Could you give a rough outline to the pros and cons of nitrous? Thanks. Sorry for all the newb questions...
            • #51
              overLl dollar for dollar nos is the cheapest way to produce hp and torque. You won't get any engine wear as long as you choose the right HP rated kit. If you go with too much up then you could see problems. Cause the components may not be able to handle the extra load. For low hp applications you should go with a dry kit to start off with. Don't go with a cheap wet kit cause you could run into problems if the fuel/nos ratio is very uneven and if you. Running lean you could get backfire and mess somes things up. However member on here found with his dry kit his injectors were running at 95% and he had to replace several of them. He went to using a wet kit and didnt have that problem,he went with a good harrispeed wet kit which are nice. Like I said the cheap wet kits I wouldnt recommend but if your willing to spend the extra bucks you could go with a wet kit
              Show
              -20% tint
              • #52
                ok. thanks. i'm mainly concerned about it melting the engine from the inside out. or deteriorating it. I was going to use the direct port wet shot from zex. good name and better than a plain wet shot. thanks again.
                • #53
                  is this what your talking about ranin?
                  Show
                  -20% tint
                  • #54
                    That crank has to turn a lot of s**t on that motor. I never realized that.
                    Black 2006 G6 GTP Leather and 3.9 liter
                    • #55
                      yes. you'd have to relocate the intake or otherwise make room for the SC, but there is space.
                      Edit: also, my name is in HUGE letters in my sig.
                      My Progression Page: click here
                      • #56
                        That is right were the intake tube goes. Now all you have to do is figure out where it is going to go.
                        • #57
                          haha i know how your name is spelled i just missed an "N" AKA typo. im not sure how i would put the intake tubing. RanNin do you want to edit my image in paint if you have an idea of where to run the intake?
                          Show
                          -20% tint
                          • #58
                            haha i know how your name is spelled i just missed an "N" AKA typo. im not sure how i would put the intale tubing. RanNin do you want to edit my image in paint if you have an idea of where to run the intake?
                            *intake*
                            • #59
                              A Centrifagul Supercharger might be a better course of action as opposed to a Roots Style supercharger. Using a Paxton Novi RR (Reverse Rotational) Supercharger would allow us to keep the intake tube going in the direction it goes now..here is a description of the difference between the NOVI 1000 and NOVI 1000RR
                              The NOVI-1000RR (reverse rotation) is identical to the original NOVI-1000, except that it is driven counter-clockwise and the supercharger mounts "backwards" with the intake facing forward. This allows the supercharger to be driven by the accessory drive belt, eliminating the need for a separate drive system.
                              Its a little hard to describe this..but im gonna try my best. What I was thinking would be..where the impeller would be connected to the Air filter and tube with MAF....instead is connected to the tube that goes to the throttle body. At least thats how i envision it. Without actually seeing one..and seeing how it would work, its very hard to visualize it in my head...Seeing the picture here (hope it works if not direct link)
                              http://www.theracecarfactory.com/assets ... r_best.gif
                              shows the SC's pulley system..and the intake tube on the SC..the tube and filter with MAF would be connected there..and the side with the impeller would be connected to the tube that goes to the throttle body so it works counterclockwise to suck the air right into the supercharger..and we could use the existing pulley system of the engine to power the thing. The only other hurdle would me mounting it with some sort of custom bracket. Since superchargers don't need a custom exhaust manifold like turbochargers do. It would might a bit more feasible. I've been doing research and trying to visualize this project as best that I could...lol..its taken me a while to collect my thoughts.. What do you guys think about this?
                              CarDomain - http://www.cardomain.com/ride/2932943
                              2006 'SS' Malibu
                              Tune Time ECM/TCM tune
                              Injen Clone Stage 4 Intake
                              Pooners C.R.A.B.
                              2 1/2" Borla Cat-Back Exhaust
                              EBC Slotted/Cross Dimpled Rotors w/ Red stuff Pads
                              Est. 227 HP 224 Torque at wheels
                              Est. 267 HP 263 Torque at crank
                              • #60
                                i myself was reading about the centricial sc yesterday. its hard to visualize it like you said.
                                Show
                                -20% tint
