What Motor Oil do you use?
  • #16
    Re: What Motor Oil do you use?
    AMSoil and Royal Purple used in this garage
    • #17
      I use mobil 1 synthetic for about everything. My GTP and Torrent GXP gets 5w 30 Mobil 1. My work vans get mobil 1 5w-30 for gas GMs, 5w-20 Fords, and 5w-40 turbo diesel oil for the Duramax. Now on my jeep I will use a Valvoline high mileage as its a 94 with 172K miles.
      I just use Mobil 1 as I always have an no issues before, I have tryed other oil if its a real great deal on an oil change special at Advanced Auto.
      Only diffrence on MPG I have ever came across is the Ford Vans with the 4.6Ls and there 2006s. You run normal oil they average 15.5 MPG. Not bad for E250s. If you run synthetic (any brand) there average is 16 MPG. My Chevy Express van a 4.8L V8 2500 or my 3500 6.6L Duramax regular or synthetic theres no MPG diffrence. Same with my GTP or the GXP.
      2006 G6 GTP: Traded
      • #18
        Synthetic oil will give you around 1% improvement in gas mileage so it's barely noticeable in real world driving.
        The main advantage with synthetic is with its stability, rather than its lubricating properties.
        • #19
          Mobil 1 full synthetic
          • #20
            valvoline max life
            2006 Pontiac G6 GTP M6
            Custom made intake, 5% tint, motor mounts, 235/50 18 firehawk wide oval a/s.
            Up next- exhaust
            • #21
              Mobil Super 5000 (Conventional Oil) With a Mobil Filter. I plan to switch to Mobil 1 Synthetic when I build the engine more.
              • #22
                Mobil Super 5000....switching to full synthetic this next change
                Progression Thread - Updates on page 1
                Show: Complete debadge, Black Eagle Eye headlights, 35% Tint, Front dart blackout, window trim blackout, front grill trim blackout, 2Crave No. 5 Wheels
                Go: Intake resonator delete, Spectre intake piping, K&N drop in filter
                , MagnaFlow exhaust, Falken Azenis PT-722 Tires
                Misc: RCA Headrest DVD players
                Pending Install:
                Enroute:
                Next idea: Lowering Springs/Spacers
                • #23
                  Used to use dino oil but will be trying full synthetic next time. Probably Pennzoil because damn I can use an extra 120 miles per tank lol
                  • #24
                    mobil 1 full syntetic only here..... 5w30 for now, 15w50 when i finish my engine lol
                    • #25
                      I use whatever my GM dealer uses lol
                      MODS:20% tint, Lumens 6000K HIDs low and fogs, Lumens white LED plate light and reverse lights, Spyder LED/CCFL Halo/Projector headlights, white/white "Switchback" LED rear tail/brake/signals, shorty antenna, debadged hatch and front doors, blacked out grill
                      • #26
                        I have used just regular conventional oil 0-60k miles. Just recently I switched to Royal Purple Full-Synthetic. I am not certain I notice a difference but I am fairly certain it is protecting my engine parts better and an oil additive that I use protects against wear at start-up. Royal Purple was I sale but I plan on trying Mobil 1 full-synthetic next time.
                        • #27
                          Generally I used Valvoline High Mile, but since I have free oil changes on the 6 I don't know what they are putting in it. I think I am going to start doing it myself. Don't know if I will go synthetic or conventional. I guess it depends on what the deal of the week is at Advance Auto.
                          2008 Pontiac G6 Base "Nothing Out Of The Ordinary"
                          2008 Ford Edge
                          My Progression
                          • #28
                            I think next oil change I'm going to go full Synthetic, Mobile 1 to be exact. I think it's a good time to make the switch to a better performing oil. I've been doing research and found a lot of advancements have been made with synthetic in the last decade or so. Specifically better cooling and lubrication, high film strength (as advertised with royal purple) and much better seal properties to prevent leaks for longer.
                            On a side note I once went from conventional oil to royal purple on my 93 Cutlass. I felt a difference instantly! Engine felt smoother, way more peppier and had the get up and go, you could feel it in that old lazy motor. BUT being an old 6 cylinder with some miles, it did find all the little leaks in the valve covers. Oh well not my problem anymore
