yeah you should do that!
INTAKE!(Any Info or questions post here except delivery inf)
750WHP Magnacharged GTO.....WTF!
TVS2300 GTO, Innovators West 8" Overdrive Pulley, ECS Tensioner, SD tuned by Andrew at Complete street performance, Ed Curtis custom Lunati camshaft 230/236 .6XX/.6XX 113 LSA, Hardened Pushrods, Lunati .675 lift Valve Springs, Single Walbro 255 fuel pump in stock bucket, Kooks 1 7/8 Jet hot coated Headers , Kooks 3" catless mid pipes with DMH low pro electric cutouts, Spintech 2.5" stainless steel exhaust with X pipe, Carbon fiber Cold air box with AEM air filter, Billet products short shifter, JamesBiz Oil catch can, Pedders 5/16" raise springs with drag bags, Weld RTS Black with Hoosiers
Show
-20% tint
-bohaman AUX-in radio mod
-Professionally heated seats
I got an email from K&N today because I think I wrote them a long time ago about available products for the 3.9. I noticed that they list a Typhoon Intake kit as "new", so I'm guessing it just came out? I don't really keep up with the number of intakes floating around, but here it is anyway.
Factory direct K&N replacement air filters, air intakes, oil filters & cabin filters. KNFilters.com - the official site for performance filtration products.
Built for performance and show, the Typhoon™ Air Intake System is a free-flowing mandrel-bent aluminum tube induction system designed to fit many sport compact performance vehicles. Typhoon intakes come in one of three designs; cold air intakes (CA), short ram intakes (SR), or complete cold air (CCA) intakes which can be configured as either a cold air intake or a short ram intake. Some Typhoon's have high quality finish options including polished aluminum (part ends with TP), powder coated blue (part ends in TB), powder coated red (part ends in TR), and powder coated silver (ends in TS) among others. K&N intake systems replace your vehicle's restrictive factory air filter and air intake housing. K&N intakes are designed to dramatically reduce intake restriction allowing more air flow to your engine. More air means more usable power and acceleration throughout the engine's RPM range. [MORE]
69-7202TTK Product Specifications
Product Style: 69 Series Typhoon Kits
Estimated Horsepower Gain: 5.22 HP @ 5195 RPM
Color: Textured Black
Replacement Filter: RU-5168
CARB Exempt: No
System Type: Cold-air intake system
Weight: 10.1 lb (4.6 kg)
Product Box Length: 36.25 in (921 mm)
Product Box Width: 13.38 in (340 mm)
Product Box Height: 10.38 in (264 mm)
http://www.knfilters.com/search/product ... 69-7202TTK
Interesting! Part number is the same and it only lists the 3.5 and 3.9 engine.
Originally posted by Hellohow much is it?
The above part costs $255.99 plus tax.
Same part number for the 3.5 or 3.9
Originally posted by LampoonOriginally posted by WoodburyMan
You dont need those straps.
Blue Silicone pm sent....
And thanks! I'll be ordering those tongiht!2015 Chevy SS, Perfect Blue Metallic, Sunroof, No Spare, M6
Appearance: Full LED Conversion, 6000L D3S HID Bulbs, Holden Rear and Front Embloms
Go Stuff: Diablew 93 Octane Tune
Missed and not forgotten. Traded.
2005 CGM GTO.
386whp, 364ft-lb torque, Corsa Sport Exhaust, Tuning, K&N Intake, VX Tails, Halo Projectors
2009 G8 GT SRM Premium Package, 6000K LED + HID Lows, Factory Bluetooth Retrofit, Atari Gauges, Factory iPod Control, 93 Octane Diablew Tune, Vararam Intake, MBR Strut Bar, Corsa Catback, DBA 4000SX Slotted + Drilled Rotors, Hawk Ceramic Pads.
AC lines aren't in the way with the "stage 4" set up. Unless your talking about your CRABs Robert?
K & N would only have to mold a different plastic tube than the 3.5 and the 3.9 inlet angle to the TB and bam! 3.6 would have like the same thing.2008 Chevrolet Cobalt SS T/C
Black/Black coupe
Look how long it took them to get the one for the 3.9 out...maybe one will come out for the 3.6 after they stop making it.
Originally posted by Lampoonhttp://www.knfilters.com/search/product.aspx?Prod=69-7202TTK
2007 G6 GT Coupe
Mike
Well I just ordered the K&N intake from autoanything and it was $228.95 with free shipping and no tax. They originally wanted 249 but I told the sales guy he had to do better and he then lowered the price. BUT I had ordered a CAB from Dr.Speed in Oct. which I paid for but have not yet received and no idea if and when it will arrive. If anyone here is interested in the Dr. Speed CAB please PM me, I will obviously be selling it when it (hopefully) arrives.
Wow. So I've been driving with the State 4 and CAB all week now. I've DEFINALLY noticed an increase in fuel efficiency. I've driven like I usually drive, with the exception of only 1 short trip on the highway rather than my usual 2 / week because classes ended, and my DIC currently read 19.5mpg . Usually by about 1/3 tank left it would say like 18.0-18.5 usually and I'd get about 17.5-18 when I fill up.
It has to something else like random coincidence as well. All I did really was go from a State 2 to a C.A.B. Blocking the heat couldn't do that much, could it?
Another note, I have to tie down the intake a bit more. I didn't bother attaching the MAF to the CAB like most people did with a bolt since I had the other brackets, but I'm going to have to. Right now, whenever I accelerate from a complete stop I hear a "eeert" from the engine, most definally the intake, I determined it was the filter rubbing on the CAB when it would shift slightly. I have to play with that later today.2015 Chevy SS, Perfect Blue Metallic, Sunroof, No Spare, M6
2005 CGM GTO.
Show
-20% tint
The last two letters in the part number indicate the finish.
Sooo a 69-7202TTP should be should be polished aluminum.- if its available. Call your local K&N dealer and see.Please consider supporting G6P -Tap here
