  • Re: EXHAUST!(Any Info or questions post here)
    Originally posted by Radiodr View Post
    Posted this once before, but wondering if anyone had tried it. Looks like almost a direct replacement for oem.
    http://vibrantperformance.com/catalo...oducts_id=1838
    Someone has already had it installed?
    sent via space transponder now Free
    Current Modifications: 18' Sky Wheels w/ 245/40-18 Tires, 25mm Spacers, Megan Racing Coilovers, Racingline STB, JPE Rear Camber Kit, Energy Suspension Poly Bushings, Painted Calipers, Double Drilled/Slotted Rotors, Ceramic Brake Pads, Street Series MMI, CRABS with FPU, NGK Iridium Plugs, Kingsborne 8mm Wires, Custom Magnaflow Exhaust, Custom 2ga Grounding Kit, DDM 6k HIDs High/Low/Fog, Halos, High/Fog Mod, Chrome Recessed Upper and Lower Grills, GM Ground Effects Kit, GXP Rear Bumper, GXP Sedan Hammerhead, 15% Tint, Custom Painted Engine Cover, Painted Mirror Caps, Tinted Tails, QuickLifts, PAC Audio Input, Interior LED Conversion, Dash LED Accents, 3W LED Trunk Lighting
      I used to have that installed on my gxp, infact I still have that muffler lol.
      2009 Ford Mustang Premium Pony 4.0L
      2001 GMC Sierra SL 4.3L
        Is that Straight pipe to that muffler only? That crackling bothers me. So far the cherry bomb glass packs setup is the only thing that's made me happy haha
          Stock cats 18" long vibrant resonator then the muffler and tips.
            Originally posted by lueshe View Post
            I installed my CRAB intake a few weeks ago, and finally installed the new exhaust on Friday. I went with:
            2.5" to 4" tips.
            It has a nice low rumble to it until I step on it. Overall, I'd say i'm satisfied. I need to take pictures and put a video together.
            this is the best sound ive heard while looking through exhaust clips, i know you said you dont know much about the 3.5 but do you know if anyone has used a similar setup as yours on a 3.5 already,,, i cant find one there are sooo many clips and exhaust posts lol
              Has anyone done a single exhaust instead of the dual? I'm thinking of doing double muffler single 2.5" cat back with 24" resonator and a muffler I'll have to look into.
                Magnaflow makes a single exit set up
                  I have a single, got some pics in my progression
                  Mods: BMD Adjustable Front End Links, BMD Stainless Steel Brake Lines, Koni Yellow Sport Dampers, Pedders Lowering Springs, Brembo Upgrade, Racingline STB, Custom Intake, 8000k Lowbeam HIDs, 10000k Foglight HIDs, Badge & Doorsill Overlays, GM G6 Logo Mats, Blacked Out Window Trim, Blacked Out Grills, Pioneer Headunit, 2 10" Kenwood Subs
                  My Progression
                  BMD Performance products
                    Saw your photos. I think I'm gonna do fully custom: cut the stock resonator out and put 24" glasspacks cherry bomb resonator, a single in and out muffler... Not sure what one yet and a single or dual Apexi n1 muffler. Yea it's an import muffler but I have it and it sounds great on the LS motors so should be fine.
                      Priced out new exhaust yesterday and have a concern. Saw a lot of people on the board ran a single 2 1/2" pipe from the "Y" back. I wanted to do this but the 3.9 on my 'vert currently has 1 3/4" factory piping. Is this too much of a stepup? Am I going to loose all my torque off the line? As we know the 'vert is the heaviest of the 6's and needs the torque to get moving.
                        Open it up. The convertible is a pig, and it's not helped by the factory literally crushing the exhaust pipes to clear the chassis bracing.
                        My Progression Page: click here
                          Yeah it is pretty bad! 1 3/4" piping and had to crush it to get past the bracing.
                            I am planning on using Magnaflow. Should I use a single in dual out or "Y" it after the gas tank and run twin muffs?
                            I have a part # of 12226 on the single in dual out.
                            Kmans car on G6OC has a twim muff system on it. Got me wonndering how much would it add/ Take away to run a single vs twins.
                              AFAIK, muffler choice and number of mufflers only affects sound. I mean, I guess there are minute power band changes between all the different types and brands, but I don't think you should be able to feel a difference between different mufflers on the same size piping.
                              That being said, Magnaflow seems to be generally preferred in this group.
                                I don't like magma flow or flowmaster. Both don't sound deep or give the throaty sound engines make.
                                Hoping to maybe put dual Apexi world sport mufflers on mine. Either straight dual or connected like stock is. No sure yet.
