Re: LY7 Upper manifold insulator (aka. more performance!!)
Heads are aluminum, so is the lower and upper intake.
I'm going to go on record saying that the spacer won't add any power, instead to prevent loss, the graph shown doesn't show you the redline though, it shows you MPH, you could be losing 10 or 15 horse at redline, but it doesn't show.
This motor stock makes it's peak power at 6K and then carries it through to redline, the fact that it shows it peaking at the end, leads me to believe that you aren't see the whole power band.
However, spacers will prevent a little bit of heat soak which can add a little bit of power, which is what your seeing throughout the power band. So for $80 its not the worst thing ever it's just that I would get it, if it didn't adversley affect the power curve so much top end like I suspect. It shows a significant gain for some odd reason only in a short span, this seems a little suspect, in any event, I seriously doubt that would add any real benefit, as that is likely in the torque converter's flash range anyways.
Shrug...
Shrug...
