Great place to run your power wire through firewall
  • Great place to run your power wire through firewall
    Sorry don't have time to run through 26 pages of posts to see if this was already posted...
    I have a 2007 manual GT coupe. Considered drilling through the firewall, but decided against it since brake booster and steering joint takes up most of the area. Existing grommet above the clutch pedal is nearly impossible to use since it consists of a grommet on either side of the firewall with rubber tubing in between. Blah.
    Struck gold behind the center console on the floor. Peeled back the carpet and the first layer of rubber insulation. You'll see two thick cables running through a large grommet. Poke the grommet with your finger and it falls right through, revealing a gaping hole you can stick your power wire through. Ridiculously easy. The hole comes out on the engine bay side towards the bottom center.
    Pics to clarify. Note hole in relation to gas pedal to give you reference point:
    ? CRAB CAB Intake (Lampoon)
    ? GT-R Exhaust (GT-R)
    ? Kustom Dekalz Overlays (Schenko)
    ? Twin 12" JL W6-V2 subs ?
    ? Dynoed @ 207.4 WHP & 215.1 Ft-Lb
    Re: Great place to run your power wire through firewall
    yep agreed, i used the same thing place but i didnt push the grommet out
      Nope, I used the one just above where you rest ur left foot. Comes out below/behind the strut tower.
      Blue Man Group Member NY Local 123
        in my v6 auto this grommet has only one cable currently going through it.. and the grommet isn't simply guna be able to be 'pushed out'.. i'm tryin to widen the hole however but lack of a drill bit is preventing this....
        wow.. finally got it.. I just ended up sticking needle nose plyers into the spot, widening em as much as i could and shoving that bulky ass 4ga wire in there... this was pretty tiresome..
          just take an air hammer and make your own hole.... thats what i did for my 0 guage
          Profession: Mobile Audio/Video and Electronics Sales
          Experience: 10+ years
          Rides: 07 Grand Prix GXP, 08 G6 v6, 78 Camaro(under construction)
