Originally posted by saywhat_playa
Best Headlights?
i think you have to take the headlight apart to take out the amber-Mike #2 (the self-proclaimed tallest G6 owner)
http://www.cardomain.com/ride/2645383
VMS ECM, GT-R Exhaust, Dr. Speed Stage 3 CAI, 35% Llumar Tint, Redline Hood Struts, Vent Visors,
Pontiac Inset Upper Grilles #1, STB, Black Euro Tails, PowerSlot Rotors, Hawk Brake Pads
I'd personally go with the nokya's. I went HID for my lows but kept the Nokya's in my highs and fogs. Fogs are still bright as can be but one high just burned out a couple weeks ago-pretty good though almost a year with them which is pretty good for high wattage bulbs. Also depends what type of color you're looking for.TRADED IN BUT NEVER FORGOTTEN: 2006 GT Coupe in granite metallic, 15/5% tint, vinyl side marker deletes, Doctor Speed Stage 3 CAI, RED calipers by DupliColor, RED LED interior lights, 45 LED tail lights, WideView 8000K HID coversion kit, Nokya Artic White fogs installed, running MoBil 1, FIRST ever granite metallic color matched headlights!! Color matched eyelids just finished! GT-R Exhaust installed. R1 Concepts drilled and slotted zinc plated front rotors.
Hey guys I have a tech question.
Just bought the Nokya Artic Whites which on the web site (autolightingusa) the bulbs are rated 55w draw/100w output.
But when I look at the bottom of the bulbs it says 12v 80w, is this the correct bulb and is it safe to use.
They are H11's part # NOK-7218.
Just want to make sure I got the right ones, I read the melted wiring harness post.
Bigrich,
They will be fine.. I bought the Piaa Xtreme's and had a similar rating, had no problem
I believe it's the initial draw that maxes out at 100w, but continous lighting is at 55w, like most bulbs..
if this helps, ur welcome, if not, sorry!!!
MikeNJBlackG6GTP
2006 G6 GTP - BLACK
Sirius and XM radio
Piaa H11 Xtreme White Low Beams and Fogs
DoctorSpeed Stage 3 CAI
35% Window Tints
Re:
Originally posted by BlackdogJust ordered PIAA’s Xtreme White Plus H-11.
$75 CDN
I'll pick them up Monday and try and get some pics posted shortly after.
Chris
got pics of the PIAA's in your car? i'm thinking of getting these and would like to see what they look like and if the output (from the drivers seat) is the same or better then stock.
thanks
