Tire Pressure Monitor System
  • Tire Pressure Monitor System
    The tire pressure monitor (TPM) system warns the driver when a significant loss, or gain of tire pressure occurs in any of the 4 tires and allows the driver to display the individual tire pressures and their locations on the driver information center (DIC).
    The system uses the body control module (BCM), driver information center (DIC), instrument panel cluster (IPC), remote control door lock receiver (RCDLR), a radio frequency (RF) transmitting pressure sensor in each wheel/tire assembly, and the serial data circuit to perform the system functions. Each sensor has an internal power supply with a 10 year service life.
    When the vehicle is stationary, the sensors internal accelerometer is inactive, which puts the sensors into a stationary state. In this state the sensors sample tire pressure once every 30 seconds and do not transmit at all if the tire pressure does not change. As vehicle speed increases, centrifugal force activates the sensors internal accelerometer causing the sensors to go into rolling mode. In this mode, the sensors sample tire pressure once every 30 seconds and transmit in rolling mode once every 60 seconds. The RCDLR receives and translates the data contained in each sensors RF transmission into sensor presence, sensor mode, and tire pressure. The RCDLR sends the tire pressure and tire location data to the DIC via the serial data circuit where they are displayed.
    The sensors continuously compare their last pressure sample to their current pressure sample and will transmit in re-measure mode if a 8.3 kPa (1.2 psi) change in tire pressure has been detected in either a stationary or rolling state. When the TPM system detects a significant loss, or gain of tire pressure, the tire pressure monitor indicator icon is illuminated on the IPC and if equipped, a check tire pressure type message is displayed on the DIC. Both the indicator icon and DIC message can be cleared by adjusting the tire pressures to the recommended kPa/psi and driving the vehicle above 40 km/h (25 mph) for at least 2 minutes.
    If power is disconnected from the RCDLR or if the vehicle battery is disconnected each TPM sensor ID is retained but all of the tire pressure information is lost. Under these circumstances the RCDLR cannot assume that the tire pressures were maintained over an unknown period of time. If equipped, the DIC will display all dashes and the scan tool will indicate a default tire pressure value of 1020 kPa (148 psi) for each tire. Driving the vehicle above 40 km/h (25 mph) for at least 2 minutes will activate the sensors causing the DIC to display the current tire pressures. The J-46079 TPM special tool or the pressure increase/decrease method may also be used to activate the sensors as well.
    The RCDLR has the ability to detect malfunctions within the TPM system. In the event a DTC is set, the tire pressure monitor indicator icon on the IPC will flash for 1 minute and then remain illuminated after the ignition is turned ON and the IPC bulb check has been completed. Any malfunction detected will cause the DIC to display a service tire monitor system type message.
    1)TPM Sensor
    2)Sensor Retaining Nut
    3)Valve Cover
    4)Rim
    Tire Pressure Indicator Sensor Learn
    Special Tools
    J-46079 Tire Pressure Monitor Diagnostic Tool
    Learn Mode Description
    The tire pressure monitor (TPM) system uses the instrument panel cluster (IPC), body control module (BCM), remote control door lock receiver (RCDLR), keyless entry transmitter, 4 radio frequency transmitting pressure sensors, and the serial data circuit to perform the TPM learn mode functions. The sensor learn procedure must be performed after every tire rotation, RCDLR replacement, or sensor replacement. Once the learn mode has been enabled, each of the sensors unique identification codes can be learned into the RCDLR memory. When a sensor ID has been learned, the RCDLR sends a serial data message to the BCM to sound a horn chirp. This verifies the sensor has transmitted its ID and the RCDLR has received and learned it. The RCDLR must learn the sensor IDs in the proper sequence to determine correct sensor location. The first learned ID is assigned to the left front location, the second to right front, the third to right rear and the fourth to left rear. The turn signals will individually illuminate indicating which location is to be learned in the proper sequence.
    Sensor Functions Using J-46079
    Each sensor has an internal low frequency coil. When the J-46079 is used in activate mode, it produces a low frequency transmission that activates the sensor. The sensor responds to a low frequency activation by transmitting in learn mode. When the RCDLR receives a learn mode transmission while in TPM learn mode, it will assign that sensors ID to the location on the vehicle relative to the order in which it was learned.
    Sensor Functions Using Pressure Increase/Decrease Method
    Each sensor takes a pressure measurement sample once every 30 seconds while in stationary mode. If the tire pressure increases, or decreases by more than 8.3 kPa (1.2 psi) from the last pressure measurement, another measurement will occur immediately to verify the change in pressure. If a pressure change has indeed occurred, the sensor transmits in Learn mode. When the RCDLR receives a Learn mode transmission while in TPM learn mode, it will assign that sensor's ID to the location on the vehicle relative to the order in which it was learned.
    Learn Mode Cancellation
    The learn mode will cancel if the ignition is cycled to OFF or if more than 2 minutes has elapsed for any sensor that has not been learned. If the learn mode is cancelled before the first sensor is learned, the original sensor IDs will be maintained. If the learn mode is canceled after the first sensor is learned, the following will occur:
    • All stored sensor IDs will be invalidated in the RCDLR memory.
    • If equipped, the DIC will display dashes instead of tire pressures.
    • DTC C0775 will be set.
    These conditions will now require the learn procedure to be repeated for the system to function properly.
    TPM Learn Procedure
    Important: If using the scan tool to enable the learn mode, the J-46079 must be used to activate the sensors. When this preferred method is used, any stray sensor signals will not affect the learn procedure. In the event a particular sensor's information is displayed on the special tool upon activation but the horn does not chirp, it may be necessary to rotate the wheel valve stem to a different position due to the sensor signal is being blocked by another component.
    If using the keyless entry transmitter or DIC buttons to enable the learn mode, the J-46079 or Pressure Increase/Decrease Method may be used. Before proceeding with this method, ensure that no other learn procedure is being performed simultaneously or that tire pressures are not being adjusted on another TPM equipped vehicle within close proximity. Stray signals from other TPM equipped vehicles just driving by can be inadvertently learned. If any random horn chirps are heard from the vehicle while performing the learn procedure, most likely a stray sensor has been learned and the procedure will need to be cancelled and repeated. Under these circumstances, performing the TPM Learn Procedure away from other vehicles would be highly recommended. In the event a particular sensor activation does not cause the horn to chirp, it may be necessary to rotate the wheel valve stem to a different position due to the sensor signal is being blocked by another component.
    Preferred Scan Tool Learn Enable Method
    Using a scan tool, initiate the TPM Learn Mode. A double horn chirp will sound indicating the Learn Mode has been enabled. The left front turn signal will also be illuminated.
    Starting with the left front tire, active the sensor by holding the antenna of the J-46079 aimed upward against the tire sidewall close to the wheel rim at the valve stem location. Press and release the Activate button and wait for a horn chirp. Once the horn chirp has sounded, the sensor information is learned and the turn signal in the next location to be learned will illuminate.
    After the horn chirp has sounded and the right front turn signal is illuminated, repeat step 2 for the remaining 3 sensors in the following order:
    3.1. Right front
    3.2. Right rear
    3.3. Left rear
    When the left rear sensor has been learned and a double horn chirp has sounded, the learn process is complete and the RCDLR exits the learn mode.
    Ignition OFF, adjust all tires to the recommended pressures. Refer to Vehicle Certification, Tire Placard, Anti-Theft, and Service Parts ID Label.
    Alternate Keyless Entry Transmitter or DIC Learn Enable Method
    Ignition ON, initiate the TPM Learn Mode using one of the following procedures:
    • On vehicles equipped with keyless entry, simultaneously press the keyless entry transmitters lock and unlock buttons until a double horn chirp sounds indicating the Learn Mode has been enabled. The left front turn signal will also be illuminated.
    • On vehicles not equipped with keyless entry, press and release the driver information center (DIC) INFO button until the TIRE LEARN message appears on the DIC display. Press and hold the SET/RESET button until a double horn chirp sounds indicating the Learn Mode has been enabled. The left front turn signal will also be illuminated.
    Starting with the left front tire, learn the tire pressure using one of the following methods:
    • Hold the antenna of the J-46079 aimed upward against the tire sidewall close to the wheel rim at the valve stem location. Press and release the activate button and wait for a horn chirp. Once the horn chirp has sounded, the sensor information is learned and the turn signal in the next location to be learned will illuminate.
    Caution: Over inflating tires may cause personal injury or damage to the tires and wheels. When increasing tire pressure do not exceed the maximum inflation pressure as noted on the tire sidewall.
    • Increase/decrease the tire pressure for 8-10 seconds then wait for a horn chirp. The horn chirp may occur before or up to 30 seconds after the 8-10 second pressure increase/decrease time period has been reached. Once the horn chirp has sounded, the sensor information is learned and the turn signal in the next location to be learned will illuminate.
    3.1. Right front
    3.2. Right rear
    3.3. Left rear
    Re: Tire Pressure Monitor System
    Stickied!
      andy do u know if the the older 6s can upgrade their bcm to handle this?
        upgrading may be possible but i am not sure what it would take obviously sensors would need to be installed the bcm would need to be replaced or reprogrammed IPC would need to be repalced for the TPM light and the RCDLR and radio would either need reprogram or replace
          hmmm sounds possible lol but i think i can probably go a cheaper route
            And what cheaper route would that be?? Just to check it with a pressure guage every so often??
            Originally posted by WoodburyMan
            Your Car sounds like it is kicking ass!. Your exhaust makes way more kickass noise than my does and i dont even want to hear mine start.. and it just sounds like the fucking MOTHERSHIP HAS LANDED!... don't know how to explain it. but my pants just got tight and now i want to make love to your car! where the beautiful sound comes from...
              Mark.
              http://<img class="bbcode-attachment...="0" alt="" />
              2007 G6 GT Sedan {My driver}
              2015 Chevrolet Equinox 2LT AWD 3.6{Wife's driver}
              1984 Camaro
                im cheap but not that cheap
                http://www.tirerack.com/accessories/detail.jsp?ID=55
                  Definitely good information, but how can you activate it at home without that special tool? I looked at the DIC and still no options for tire pressure?
                  Wife's 08 G6 - Stock
                  Mine 01 GP GT - Too many mods
                    Those tire pressure sensors are a bitch. I just got new tires put on and the guys who went to take them off busted one of them when unscrewing the valve stem...Cost me $70 bucks!
                    I heard it's a problem with most vehicles equipped with these sensors because they have to be torqued in place and are very delicate and easy to break.
                    "Now I am become death, the destroyer of worlds"
                      shouldn't have cost you a dime. a moron broke it, you didn't. their problem to replace.
                        Blue 2008 G6 GT Sedan-Sold
                        In its place- Fully loaded Black 2013 Chrysler 300C AWD 5.7L Hemi V8
                        Originally posted by zlatsky
                        I <3 Cody.
                        No homo.
                        i <3 cody
                        lots of homo
                          Thing is...I told them that, but they were like no we can't do that....hell even the dealership said i still had to pay for it in full even though its still under warranty.
                            I <3 Cody.
                            No homo.
                            i <3 cody
                            lots of homo
                              with keyless entry turn the key on and press and hold lock and unlock until you hear a horn chirp.
                              then
                              starting at the left front
                              3.1. Right front
                              3.2. Right rear
                              3.3. Left rear
                              and yes if they broke the sensor they should have paid
