F40-6 Speed MTX
    Re: F40-6 Speed MTX
    what do you guy think top speed will be winging the motor at 6,000 rpm?
    will 550hp be able to keep up with the supercharge 2008 vette?
    my F40 swap is almost completed.
    http://www.lesabret.com/phpBB/viewtopic ... &start=150
    This transmission is easier to swap to the 3800 series I and II, with compare to the 86-91 3800 v6.
    WWW.INFOWARS.COM
    1989 buick t-type,2004 GTP Comp G powertrain - R.I.P.
    1989 BLT (fully loaded) 3800 turbocharge/intercool (under the knife)
    1986 buick GN ..... 9`s DAILY DRIVER, C6 brake "STOP ON A DIME" (Summer)
    FASTER THAN YOUR OVER PRICE SPORT CAR....
    http://s73.photobucket.com/albums/i232/ ... rformance/
      Re: F40-6 Speed MTX
      That looks complicated... and awesome!
      My Progression Page: click here
        Re: F40-6 Speed MTX
        about both. i tihnk this is the 2nd time i with you today!
        Show
        -20% tint
        -bohaman AUX-in radio mod
        -Professionally heated seats
          Re: F40-6 Speed MTX
          It's cause great minds think alike!
            Re: F40-6 Speed MTX
            The project is still comming along. Some of the parts are on back order from GM (shifter boot, and botton). so far I was able to mount the 6 speed shifter, with cable. The shifting is nice and smooth.
            pretty soon
            http://lesabret.com/phpBB/viewtopic.php?f=1&t=6730 LOVE IT. glad i`m not apart of the BLT.forum anymore, cause of thos mud-hole...
            bad things will alway happen to bad people...
            WWW.INFOWARS.COM
              Re: F40-6 Speed MTX
              Does the cable on the left engage reverse?
                Re: F40-6 Speed MTX
                the black cable engage the reverse gear. the white cable slide the gear selector into the 1-2 / 3-4 / 4-5 and reverse row.
                WWW.INFOWARS.COM
                  Re: F40-6 Speed MTX
                  after ripping mine apart last night and playing with it i was under the impression that the white cable determined reverse, 1/2, 3/4, 5/6 and the black cable determined up or down...
                  Fusion Orange Metallic Owner? Click!
                    Re: F40-6 Speed MTX
                    Ok. i got my axle completed. here is the F40-L67 hybrid axle. both side must be same lenght when install in H-body.
                    i will install tomorow.
                    Now i can focus on the engine. all mounts and trans related modification are complete.still have to work on the turbo downpipe.
                    WWW.INFOWARS.COM
                      Re: F40-6 Speed MTX
                      sorry for the hijack.
                      WWW.INFOWARS.COM
                        Re: F40-6 Speed MTX
                        you're badass by the way... which parts are from the f40 and which are from the l67? i would be way interested in how you make the tranny hold up to more power as well
                          Re: F40-6 Speed MTX
                          the inner is from the f40 (inner hub and tri-pod bearing) the shaft and outter cv joint is the L67 (supercharge). the shaft was cut and spline (copy) the same has the f40 inner shaft then a clip is place on the end of the shaft, so the tri-pod does not get rupture during heavy (HP) rotation. cutting the spline is time consuming and the tri-pod MUST fit tight to the shaft spline.
                          My project continue here: http://www.gearsgarage.com/ggforum/gene ... l#post3064
                          thank you by the way.
                          WWW.INFOWARS.COM
                            Re: F40-6 Speed MTX
                            Originally posted by Kman View Post
                            If you have a 2006 G6 GTP with the revised tranny, you probably have a slightly quicker car. The revised F40 6 MT was on GTP's built after January 1, 2006.
                            Old post I know. But this is the first I've heard of it. Not that I'm going to swap my perfectly working F40 transmission out if its not the revised trans, but I have only read that 2007 model years got the revised gearing for the F40.
                              Re: F40-6 Speed MTX
                              The revised tranny still has the grinding issues that the 06 does. Just a bit less wide spread. Its only faster because of the low gear ratio its equipt with. But faster as in maybe a .1 of the second at best.
                              2006 G6 GTP: Traded
                              2013 Mustang GT
                              Gotta have it Green color
                              Brembo brake package
                              420 HP 5.0L
                              Ford Racing Power Pack
                                Re: F40-6 Speed MTX
                                My post was more about nailing down the time when GM switched to the revised gearing and proof there-of.
