ok cool ... I'll see if the dealer can take it in today ... if they can't I'll have to find some other way to get to work tomorrow ... damn ... ah well .. other than that I really like my tune so far ... thanks again Chris
Sorry bout that, there are so few six speed manuals that I completely forgot to mention it
Chris White http://www.GTOShiftLight.com
2006 Spice Red GTO - Stock
2012 Cherokee SRT8 - Stockish
had a couple hiccups ... they tried to reflash everything when doing the relearns .. apparently part of the procedure ... it didn't work .. meh whatever now they're confused .. but my car starts and runs on it's own again with no CEL ... YAY !
Hmm, is memory serves me right, Chris locks his tunes. So i am not sure if that caused the hiccup. If it is, then the reflash would have wiped out the tune.. I believe, i could be wrong..
Hurricanes are like women : when they come, they're wet and wild, but when they leave they take your house and car.
I was under the impression that it is impossible for the dealer to retune Vector's ECM, therefore the only way to go back to stock is to replace the ECM.
I wouldn't LET them reflash ANYTHING. I told them if I had to put the old ECM in, I would.
I don't know if that's what makes my situation different than yours, but I had the *exact* problem you described in your first post. But as Chris said- my clutch sensor had no resistence, so that got replaced. Then they did my crank relearn.
