Engine Type
60 degree V-6
Displacement
3.9L
238 cu in
RPO
LZ9
VIN
1
Bore
99 mm
3.90 in
Stroke
84 mm
3.31 in
Compression Ratio
9.8:1
Firing Order
123456
Spark Plug Gap
1.00 mm
0.040 in
Block
Camshaft Bearing Bore Diameter - Front and Rear
55.26-55.31 mm
2.175-2.177 in
Camshaft Bearing Bore Diameter - Middle #2, #3
54.75-54.80 mm
2.155-2.157 in
Crankshaft Main Bearing Bore Diameter
72.1535-72.0695 mm
2.840-2.841 in
Crankshaft Main Bearing Bore Out-of-Round
0.008 mm
0.00031 in
Cylinder Bore Diameter
99.000-99.018 mm
3.897-3.898 in
Cylinder Bore Out-of-Round - Diameter - Production
0.026 mm
0.0010 in
Cylinder Bore Out-of-Round - Diameter - Service
0.030 mm
0.0011 in
Cylinder Bore Taper - Production
0.026 mm
0.0010 in
Cylinder Bore Taper - Service
0.030 mm
0.0011 in
Cylinder Head Deck Height
224 mm
8.818 in
Cylinder Head Deck Surface Flatness
0.05 mm per 150 mm
0.0019 in per 5.905 in
Valve Lifter Bore Diameter
21.417-21.455 mm
0.843-0.844 in
Camshaft
Camshaft Bearing Inside Diameter
51.500-51.525 mm
2.028-2.029 in
Camshaft Journal Diameter
51.415-51.440 mm
2.024-2.025 in
Camshaft Journal Out-of-Round
0.025 mm
0.001 in
Camshaft Lobe Lift - Exhaust
6.9263 mm
0.2727 in
Camshaft Lobe Lift - Intake
6.9263 mm
0.2727 in
Cooling System
Capacity
12.4 liters
13.1 quarts
Thermostat Full Open Temperature
195 degrees
Connecting Rod
Connecting Rod Bearing Clearance
0.18-0.062 mm
0.0007-0.017 in
Connecting Rod Bore Diameter
60.322-60.338 mm
2.375-2.376 in
Connecting Rod Bore Out-of-Round
0.006 mm
0.00023 in
Connecting Rod Length - Center to Center
150 mm
5.9 in
Connecting Rod Side Clearance
0.200-0.241 mm
0.008-0.009 in
Crankshaft
Connecting Rod Journal Diameter
57.122-57.138 mm
2.248-2.249 in
Connecting Rod Journal Out-of-Round
0.005 mm
0.0002 in
Connecting Rod Journal Taper
0.005 mm
0.0002 in
Connecting Rod Journal Width
21.92-22.08 mm
0.863-0.869 in
Crankshaft End Play
0.060-0.210 mm
0.0024-0.0083 in
Crankshaft Main Bearing Clearance - Except #3
0.019-0.064 mm
0.0008-0.0025 in
Crankshaft Main Bearing Clearance - #3 Thrust Bearing
0.032-0.077 mm
0.0012-0.0030 in
Crankshaft Main Journal Out-of-Round
0.005 mm
0.0002 in
Crankshaft Main Journal Taper
0.005 mm
0.0002 in
Crankshaft Rear Flange Runout
0.04 mm
0.0016 in
Cylinder Head
Combustion Chamber Depth - at Measurement Point
2.2 mm
0.087 in
Surface Finish - Maximum
2.8 RA
Surface Flatness - Block Deck
0.08 mm per 152 mm
0.003 in per 6 in
Surface Flatness - Exhaust Manifold Deck
0.1 mm
0.004 in
Surface Flatness - Intake Manifold Deck
0.1 mm
0.004 in
Valve Guide Bore - Exhaust
8.01 mm
0.315 in
Valve Guide Bore - Intake
8.01 mm
0.315 in
Valve Guide Installed Height
16.6 mm
0.654 in
Lubrication System
Oil Capacity - with Filter
3.8 liter
4.0 quarts
Oil Pressure - @ 1850 RPM
207-310 kPa
30-45 PSI
Oil Pump
Gear Diameter
38.05-38.10 mm
1.498-1.500 in
Gear Pocket - Depth
30.52-30.58 mm
1.202-1.204 in
Gear Pocket - Diameter
38.176-38.226 mm
1.503-1.505 in
Gears Lash
0.094-0.195 mm
0.0037-0.0077 in
Relief Valve-to-Bore Clearance
0.038-0.089 mm
0.0015-0.0035 in
Pin
Piston Pin Clearance to Connecting Rod Bore - Press Fit
-0.004 to -0.021 mm
-0.0001 to -0.0008 in
Piston Pin Clearance to Piston Pin Bore
0.002-0.010 mm
0.00008-0.0004 in
Piston Pin Diameter
23.952-23.955 mm
0.942-0.943 in
Piston Pin Length
64.21-64.44 mm
2.57-2.53 in
Piston
Piston Diameter - Production
98.970-99.008 mm
3.896-3.897 in
Piston Diameter - Service Limit
98.950 mm
3.895 in
Piston Pin Bore Diameter
23.957-23.962 mm
0.943 in
Piston Ring Groove Width
1.22-1.24 mm
0.048-0.049 in
Piston to Bore Clearance - Production
-0.008 to +0.048 mm
-0.0003 to +0.0018 in
Piston to Bore Clearance - Service Limit - Maximum
0.080 mm
0.003 in
Piston Ring End Gap
First Compression Ring
0.15-0.30 mm
0.006-0.011 in
Second Compression Ring
0.25-0.45 mm
0.009-0.017 in
Oil Control Ring
0.15-0.65 mm
0.06-0.025 in
Piston Ring to Groove Clearance
0.03-0.065 mm
0.001-0.002 in
0.02-0.055 mm
0.0007-0.002 in
Oil Control Ring
0.01 mm
0.004 in
Piston Ring Thickness
1.175-1.190 mm
0.046-0.047 in
1.475-1.490 mm
0.058 in
Oil Control Ring - Maximum
2.50 mm
0.098 in
Valves
Valve Face Angle
45 degrees
Valve Seat Angle
46 degrees
Valve Seat Depth - Exhaust - From Deck Face
8.9-9.1 mm
0.350-0.358 in
Valve Seat Depth - Intake - From Deck Face
7.9-8.1 mm
0.311-0.318 in
Valve Seat Width - Exhaust
1.70-2.0 mm
0.067-0.079 in
Valve Seat Width - Intake
1.55-1.80 mm
0.061-0.071 in
Valve Stem-to-Guide Clearance
0.026-0.068 mm
0.0010-0.0027 in
Valve Lifters/Push Rods
Push Rod Length - Intake
146.0 mm
5.75 in
Push Rod Length - Exhaust
152.5 mm
6.0 in
Valve Springs
Valve Spring Free Length
48.5 mm
1.89 in
Valve Spring Installed Height
43.2 mm
1.701 in
Valve Spring Load - Closed
320 N 43.2 mm
75 lb 1.701 in
Valve Spring Load - Open
1036 N 32 mm
230 lb 1.260 in
Valve Spring Total Number of Coils
6.55
